New Experience Public Release Feedback
Yep there was a ton of outcry about it back then and they switched to the sidebar navigation. It’s like nobody at Plex remembers history.
I’m just adding my voice here: please roll back this completely unusable app.
This is no longer the time to try fixing the bugs that make it unusable—just acknowledge that there was a misstep.
It’s not glorious, sure, but it’s still less damaging than being stubborn. The app ratings are still averaging out decently on the stores, thanks to inertia.
Put the old app back on the stores, either replacing this one or as a new “Legacy” app.
Since the update, I haven’t been able to watch a single piece of media without interruption…
I would like to know the name and the competences of the person who gave green flag on the plexamp app release. You guys should have something in mind, but sure you don’t want to release good products anymore
today i had to use safari browser with plex web to play my content in my iphone because the new app is just unusable. New app just crashes or stucks playing downloaded content. Good job converting an alpha build to “stable” app.
Today re-tested with the latest build available to me and the requirement to be online to view & play content seems to have been removed as its working now. The client shows an offline banner and local content can be accessed.
I have removed that item from my reaction post above for clarity and anyone else reading the threads.
and still cant download any videos
Are you getting an error? Could you maybe provide a screenshot and some logs (including the server logs)?
just did some more testing and some stuff will download and others wont
Plex Media Server Logs_2025-04-08_22-14-21.zip (3.9 MB)
for some reason the transcoder is using cpu instead of my gpu even though hevc encoding is set to always
ok spoke too soon, i let it finish the transode but it still failed the download
some stuff will fail straight away while others will transcode but fail to download
Plex Media Server Logs_2025-04-08_22-29-04.zip (3.9 MB)
@drzoidberg33 ; do you have any updates regarding the languages? Thank you.
I just really miss being able to shuffle episodes on Chromecast. I have a Nest Hub I use for shows to sleep to and I used to just connect, shuffle and set a sleep timer on Plex. When I do that now, shuffle plays on the phone and still has those features. To play a show on Chromecast, it has to be in order and the only options I have are the playback controls, tracking, and volume. This new app has been nothing but trouble for me. At first I had to allowlist a domain to get casting working. Before that, I had to play a trailer and then go back to the show to get it to work. Buggy is an understatement.
BUG REPORT:
  1. Fast forward 30s doesn’t work in portrait player mode (works in landscape, but doesn’t work after unlocking landscape and flipping to portrait).
  2. Loading playlists is very slow
  3. Can there be a global option to not force all videos to landscape view?
BUG REPORT:
Selecting or clicking on the Cast button appears to be a dead link or icon, as it does nothing.
Device:iOS 16 Pro Max 18.5
App:iOS 2025.11.1
New app is horrendous. This may be worse than the Sonos app debacle. I use Plex to stream my own media. This app makes it infinitely worse and more difficult. The app is slow, buggy, ugly, unintuitive and just an absolute mess. I tried it during the beta, and uninstalled it after 5 minutes. It’s just as bad now as it was then. Absolute dogwater app. Y’all should be firing people who were in charge of this redesign.
I have the same issue. And my own Live TV is gone. It crashes on open. Such a big bullshit update. Inreally hope that a lot of people at plex will loose their jobs for what they did!
I tried to use the new app for the past few days, and just can’t, it is simply not ready.
  • Navigation through shows is a disaster, so many clicks to get through Show / Series / Episode. Unless I’m missing something (ie to get back to library view from Episode view, does a shortcut exist?)
    i.e. To get back from Episode view to library. Click back arrow, click back arrow, click x
  • No download indicator where a show has been downloaded.
  • No playback sync of downloaded media
  • No skip intros, adverts or outros
  • Live TV (via network tuner) is totally non functional
  • App seems to want to transcode for all files for me, things that previously direct played
    And many many other items.
I acknowledge that some of these items are on the to-do list, however most should have been mandatory for initial release.
Glad Infuse exists to be honest.
if you are on windows you can use this to downgrade
the version you want is -871812101
You might be seeing this issue:
No longer function anymore for the “Cellular Quality”. I have set this "settings > “Video & Audio” > “Cellular Quality” for mobile data rate on “2.0 Mbps, 720p”. It kept using the :Max: rate. It did surprise me cos I received the alert from my data provider that my phone data was about to run out.
Plex team. pls help to fix.
I am using Iphone 14 pro. IOS is 18.4. Plex for iOS is 2025.11.1(992).
I reported this and it’s being looked at :folded_hands:
