New PLEX version for Panasonic - When?
Get a streaming box.
Yeah, @morpheus284 it kind of speaks for itself. If the product you use is not supported then you either hack around to find your own solution (software) or by buying a streaming box/roku/chromecast/fire etc
, if that doesn’t work then change the product you are using, be that either your TV (Hardware) or Plex (Software).
I use an Xbox One S which works great with the GZ1000.
I use a universal remote control to make it super easy for the family to use. The Xbox has a built in IR port unlike other consoles.
Expected solution!
