Model Code: UA65TU8500SXNZ
Software Version: 1115.5
Plex App Client Version: 5.0.12
Platform Version: 5.5
Hi all, I dont know if these issues have been reported, the thread has grown quite dramatically, so I’ll list what I’ve found so far:
- Menu items when highlighted, are not showing text. The menu item still exists, and you can select it, but the text seems to be covered by the highlighing box. This is not a deal breaker, but it happens on all episode menus within the preview
When playing music for longer than the screensaver timeout, the plex client occasionally crashes. It is not possible to recover from this with normal means, as the TV keeps the Plex app running in the background even when on standby. The only solutions I have found so far, are to remove the Power from the TV completely, or reinstall the app.
Any video that is direct playing and contains ASS subtitles crashes immediately upon trying to display the subtitles. The only workaround I’ve found for this is to disable direct play/stream, and force transcoding to 0.7Mb/s. Any higher than this (say 1.5Mb/s will also suffer from the issue, though to a lower extent).
The next one is going to be more difficult to troubleshoot, but every now and then (about 1 in 5), a video will freeze, but the audio will keep playing. This doesn’t crash the app however, and stopping the video will allow you to go back to the main menu. Replaying the video from the beginning does not solve the problem, and the video will stop at exactly the same point every time. Forcing transcoding by lowering the bitrate/resolution seems to solve the problem, but puts excess strain on the server.
Another difficult one, is that every now and then (about 2 in 5), the audio will stop, but the video will continue to play. As above, stopping the video will allow you to go back to the main menu. As above, replaying the video from the beginning does not solve the problem, and the audio will stop at exactly the same point every time. Again, like above, forcing transcoding by lowering the bitrate/resolution seems to solve the problem, but puts excess strain on the server.
Episode details, and show details are missing from most videos (the synopsis from TVDB/MovieDB). Even though they display in Plex Web, they aren’t displaying on the vast majority of content in the Samsung Tizen-Preview.
The main type of videos that are affected by the above issues, are Anime. I’ve been working mostly with HEVC 10-bit video, and stereo/multichannel AAC audio (most contain ASS subtitles). However, I have been noticing it more and more on normal videos; TV Shows and Movies.
If there is anything else I can do to help, like provide logs etc, please let me know.
Thanks for your work! I look forward to seeing the project become stable, and adding it to my daily routine ![]()
