New to Plex. Please help me troubleshoot direct play!
Hello, I’m brand new to Plex and trying to evaluate this vs. Infuse on my Apple TV.
Here is my setup:
  • Ubiquiti USG router with several VLANs
  • Synology DS1821+ running DSM 7 on main VLAN
  • Laptops on main VLAN
  • Apple TVs on IoT VLAN
  • PiHole/Unbound on management VLAN
  • All connections are ethernet
I downloaded the latest Plex install for synology from the Plex website and was able to install it and point it towards my media. I added the
private-domain: plex.direct
line to my PiHole config. I created my libraries and can see them in PMS.
So far so good. I downloaded the Plex app for Apple TV and was able to find my PMS and everything seemed to be working…until I started to play something.
I tested out a Blu-ray rip of Cars. This was a direct rip from a Blu-ray using MakeMKV. I didn’t use Handbrake or anything to get the file size down, so it is a direct 1:1 copy of the disk.
When I played this, the quality was horrible and it was being transcoded down to 320p. So I turned off transcoding and now it won’t play at all.
In contrast, I also have Infuse on my Apple TV and it plays this flawlessly.
What am I doing wrong? Thanks!
From the looks of it, Plex considers the connection to be remote due to the VLANs.
This will apply a number of restrictions to your stream (e.g. the server remote stream bitrate limit or your client’s remote streaming quality settings). While you can remove those, that’s probably not fixing the underlying “problem”.
Another potential issue could be a bad remote access setup (again… considering all the VLANs) – this can cause those “remote” streams to be relayed through a server of Plex; those “indirect” streams are restricted to 1 Mbps (2 Mbps for Plex Pass members).
To address the root cause you could check your network setup in general.
You might be able to tell Plex that the IoT VLAN is part of your local network (see Settings > [Server Name] > Network > LAN networks; IIRC this is a Plex Pass feature).
https://support.plex.tv/articles/200430283-network/
Yep, this was my thought as well. I am pretty amazed that changing network settings is a Plex Pass feature, though. I shouldn’t have to subscribe to something just to get it to work!
Thanks.
You can change tons of network settings – some however are subject to a Plex Pass membership. I suppose it comes down to Plex being a business and giving their stuff away for free will not cover their expenses/wages/… TL;DR: their product, their rules as for what they make a paid feature
You could try giving your NAS a connection to your IoT VLAN as well. The Plex app on the Apple TV should be able to reach it directly then, without crossing VLANs. Just ensure that the main VLAN interface is the primary.
This has configuration implications. Plex Media Server isn’t able to use any interface without a default gateway configured, so you’ll have to ensure that’s done for the NAS’ IoT VLAN interface. You may also need to then take special care to restrict inbound traffic to your NAS via its IoT VLAN interface to Plex (block everything else). Probably other things as well. But you should be able to make this work.
You can download and install Netflix for free.
Should you also be able to stream from them for free?
Respectfully, by your description of your VLANs, There are times when you SHOULDN’T do something just because you can.
Synology is a very networking-restrictive machine.
Recommend you grossly simplify your network topology.
Consider:
  1. IoT devices should be like your guest Wifi – No access to any LAN resources
  2. LAN devices have access to your PMS server – On the same Subnet & VLAN.
By this definition, you have 2 VLANs. Guest/IoT and LAN/Main.
Somewhere you will have the singular edge device (the Unify) which connects to WAN.
This will put your AppleTV on your LAN, not IoT.
IF you had a linux machine, or a Synology machine with multiple adapters, you could split the Syno into two subnets (on separate VLANs).
See where I’m pointing you?
Soooo………you trust Synology over an Apple TV? To each his own I suppose.
Anyways if you want it to work between those VLANs/Subnets using a free account take the following into consideration:
  • The connection will be considered remote by PMS
  • Make sure LAN dest IP and TCP port 32400 is allowed from source IoT IP within the UniFi
  • Test this by probing PMS IP on port 32400 using nc -vz plex.server.ip.address 32400
  • Do not limit remote bandwidth under Remote Access settings
