New Transcoder Action settings - fantastic!
https://github.com/stoffez/PlexConnect
You should create a FORK. Not a new whole new project.
lol no idea how to do that :P
Well, start at https://github.com/iBaa/PlexConnect and press Fork (upper right corner). It's not that hard...
am only getting conflict when i try to sync my stuff :(
it should now work :)
is it just a matter of me replacing my templates in Plexconnect with yours?
Yes :slight_smile: but u need to have ios 6 for it to work cause the fanarts is only supported there
ok thks will give it a go
So can’t get this to work after using Stoffez’ templates in GitHub.I downloaded Stoffez’ Plexconnect zip file from GitHub,extracted and replaced my template folder with his.
Can access Trailers and I can see all my Movie and TV posters but if I try access the Play screen I get “Trailers unavailable”.If I switch back to my original templates all works fine.
Running Plexconnect 0.3.1+ downloaded 12 Jan 2014,PMS 0.9.8.18.290,Windows 7 64 bit,ATV 3(v 6.02 - 6646.81.1).
Any input appreciated.
i had a simular problem in the beginning.. try access a movie then when it says trailers unavalible. try back out and then back in again on the same movie se if it works
Thank you.Will try and see if that works.
No luck unfortunately.Will keep troubleshooting.
i found whats wrong with it.. give me an hour i will fix it
that’s great news,appreciated.
check this thread..
https://forums.plex.tv/topic/85860-fanart-possible/page-9
looks amazing!
