Newb....please help
I am a newb to Rasplex. Love it! But need to know what usb wireless keyboards or wireless remotes will work with Rasplex. Need hardware suggestions on what is know to work.
Thanks!
http://www.amazon.com/Logitech-Wireless-Keyboard-Built-In-Multi-Touch/dp/B005DKZTMG
I know works with Rasperry Pi.  Should work for Rasplex.  Check around on this one.  It's pretty well known.
Thanks!
Use your TV remote, if your TV is CEC enabled, most modern TVs are, personally I use one of these http://www.msldigital.com , some people use Harmony remotes, suggest you do a search of the Rasplex forum, both of your questions have been answered many times.
Regards.
Hello,
I am using this . It exists also in BT version
A miniature USB keyboard is really the best choice for RasPlex, as it's the only way to get access to all functionality of PHT, which is very much keyboard oriented. CEC remotes may give you the basic DPad navigation and a few special command keys, but only a full keyboard will give you all the abilities of PHT, such as the Shift-letter quick-jumps through a large media section, and many other letter-based commands. (S=subtitle toggle, L=Language choice, I=Info, C=Context menus, etc)
There are many different mini keyboards available, like the one Valyno recommended or differently designed, and all that I've tested work fine with RasPlex.
I would advice you to get one with a normal RF dongle rather than the Bluetooth variants, as all bluetooth units I've tested waste battery like crazy.
Their charge usually runs out in just a few days, whereas those with normal RF dongle can last for several months. (Varies with brand/model of course.)
Best regards: dlanor
