Setting up RASPLEX without Keyboard
I am thinking of getting a pi3 to run Rasplex on it.
I do not have any sort of USB keyboard to connect to the Pi to go through the initial set up. Is it possible to do it without a keyboard? I do have a Flirc I could use with a simple remote to give me the arrow keys and enter and I do have plex on my iOS device.
Will that be enough?
You don’t need a keyboard at all, if you have a TV with CEC then you can use your TV remote to control Rasplex. If not then FLIRC works fine.
Regards
Hi Wigster
As long as you can copy the files to the SD card then you will be fine. I installed mine via a laptop and a sd card-usb adaptor, plugged it into the HDMI from the TV and was up and running straight away, I didn’t even need the Flirc as the CEC settings picked up the TV remote. No keyboard required throughout the process.
The CEC on my v old Sony Bravia seems to detect RasPlex as the device but does not seem to be able to browse the menus with the remote. I’ve done it with Flirc in the end. Thanks!
@AprilNine said:
Hi Wigster
what files???
thank you
I think he means write the image to an SD card, simply use GetRasplex for this.
Regards
i havent usb keyboard and i need setting rasplex, but i don’t know.
what i have modify? static ip and id plex? what file is?
thank you
