Sorry im new to plex and i apologize if i describe or use the incorrect terms.
Right now i have plex running on my computer. Specs are
Windows 11 Home
Asus Tuf x570 Pro Wifi6
Ryzen 7 5800x
32gb 3200mhz ram
Nvidia Geforce RTX 3080 Ti
1TB NVME SSD
4TB x 2 Hard drive ( Western digital)
My issues are 2 different i believe but could be related.
I stream from my PC which is LAN to 3 tvs which are all wireless, these show as remote servers but are all local. My PC uses IPV6 and so does my 1 TV.
My LG 4K TV will only play movies etc if settings are set to allow secure connections - NEVER. Otherwise i just get the loading symbol and a tv show or movie does not play.
I have a Roku TV which is in my sons room, only a 720p tv and works perfectly through the app with no setting adjustments required.
LG 4K OLED in my lounge, again works flawlessly with the LG app installed and no setting adjustments required.
LG 4K in our bedroom, app installed and will only work with the network settings changed to allow insecure networks - NEVER.
ALL tvs show as remote, but are all connected to the same network.
Have enabled both Treat WAN IP As LAN Bandwidth and Enable Relay which i think were enabled by default.
Thank you in advance!
Just an update, now the tv connects, displays icons. Is very sluggish and doesnt not load or play any movie or tv show. Just get the spinning circle for awhile then unexpected playback error. Weird thing is the logs show no mention of the lg tv connected. Like its ignoring it. The one time is said lg tv connected and unknown profile. But after a few tries it assigned generic profile and the movie played. But after closing the app it went back to not playing.
