Version 1.14.0.5465
Downloaded and upgraded 4 systems, all show no remote access…
But remote access is working…
Nothing I do will get it to say remote access is enabled…
Version 1.14.0.5465
The newest version was released earlier today and is 1.14.0.5468 which should solve the remote access issues you’re experiencing.
Thanks, I’ll give it a try…
Just installing the new version fixed it… didn’t have to do anything else.
Now just the movie poster problem
PROBLEM SOLVED!.. I also installed this newest beta version however, this DID NOT solve my issue(s)…what did work was going to the settings>apps>system apps of my 2017 Shield TV and deleted BOTH cache and data of my PM Server! This gave me back remote access and I was also a able to reset the DVR once I reset the server in the Shield TV. I am using the HD Homerun Connect Quattro by the way.
