I just tried this PlexConnect and while it seems to work really well, I'm missing the option to choose a 20mbps quality setting in the options. It seems to go up to 1080p 12mbps. Is that right? Is there a way to change this and go higher? Cause my network/server should be able to handle it easily.
Either way, thanks for the great work on this amazing hack!
Elans version has the 20Mbps and 40Mbps option but it doesnt have the pause crash bug fixed, so right now you have two options, deal with the low bitrate until Baa updates his to support it or use Elans version which has them but if you pause it will crash back to the play screen upon resume (it will resume from where you last left it off though).
These options will be added but at the moment there are important under the hood changes being made in preparation for the merge and other work.
Personally I think you are better sticking with the main branch, consider Elan’s branch a preview of some things to come that you might want to check out.
