I am having a problem with the show Fairly OddParents. As it is a kids show, several files are two episodes in one. The TVDB has two ordering systems where some episodes are two in one like my files, and others are the individual episodes. TMDB has every episode separate.
The problem is that my files are not separated in the same as TVDM or TMDB. But it does have them like IMDB. I am trying to find a way to use this last database to no avail.
The only other solution would be to manually edit all the double episode files to separate them or fix TVDb, if it is even wrong
