No audio on DVR Recordings on Samsung Smart TV
I have just tested on 1.27.1.5916 and I still have the issue.
Live TV works all ok, but playing something already recorded I don’t get any sound at all.
Would this fix only work on new recordings since the new server version, or should all media play audio now?
This is a completely and unrelated issue you are seen
Please upload your recording somewhere, and DM me the download link, and I’ll try and reproduce
File received, and post moved to separate thread
Sorry about the delay here :frowning:
I simply can’t reproduce your issue.
Could you in the Samsung App settings enable log to server
Then reproduce, and right after, upload a zip with PMS Logs
no problem, i will pm you the log zip
I tried re-installing the app, and then also resetting the app and re-setting up, but still the same issue, live tv all ok, but playing back the recording of the same live tv and no audio, only video.
Sadly, you only have info logging enabled :frowning:
We need debug info
I (think) i have PM’d you the logs (this time), another school boy error.
Hi @dane22 , Any luck with the logs?
Hi @dane22 ,
I have just checked again after re-installing the latest Samsung app and upgraded to the latest production release of PMS ( 1.28.0.5999) and I still have the issue.
Have you had a chance to take a look at the logs / found anything in the logs that could show what is going wrong?
Sadly tried everything I could here, on different versions of both PMS and Samsung Client, but simply can’t reproduce :frowning:
I’ve opened a ticket to the developers for ideas just now, but since this is not a known/wide spread issue, I kindly ask for your patience
ok, thanks @dane22
(any progress?)
Nothing yet, and can take a while, sorry
Do you need more logs / info from my side?
Its been 6 months now that we have not had audio on recorded tv, is there some way I can assist in speeding up the investigation?
I just checked again on the current latest (Samsung app v 5.44.6 and server 1.28.1.6104) a we still have the same issue, live TV works ok with audio, but recorded tv there is no audio.
No, it awaits dev time, and sadly, since a problem only you reported, it’s not high on the list, and I also couldn’t reproduce
Hi @dane22 ,
I have been taking a look around and doing a bit of testing and found that all the media with audio codec of AAC_LATM are the ones which dont have sound when playing on the Samsung Plex app, and all live tv recordings record as AAC_LATM.
A recording of live TV has the following audio codec info and has no sound on the TV:
I then used the optimized versions and optimised using the “Optimized for TV” setting and this then converted to include audio codec AAC:
(using the Samsung TV Plex app only the AAC codec audio channels are in the list and not the AAC_LATM, but using the Plex web UI both AAC and AAC_LATM are in the list)
This version works all ok on the TV with audio, and looking around different media I have all the ones with AAC work perfectly with audio and all the ones (which happen to be live tv recordings) have the AAC_LATM codec where the audio does not work.
Is there any way of forcing live tv to be recorded with the AAC codec and not AAC_LATM?
I am experiencing the same problem. I have a Samsung AU9000 TV and a HDHomeRun Connect Quatro. My plex server has run on both Synology NAS and NVidia Shield (V4.84.1).
When viewing any of the UK HD channels recorded or live (all broadcast in AAC_LATM) I get no audio so need to transcode. The SD channels all work correctly (broadcast as MP2 stereo)
I can view the HDHomeRun on my TV using DLNA connection and the audio runs fine so the TV can decode the ACC_LATM audio.
Watching the Live TV on Android tablet or iPad the audio runs fine.
Hope this helps the debugging
hi @dane22
Any news on this?
This is still an issue for me, have rebuild the server from scratch and have had a few app updates on the tv, but still no audio on recordings
Sadly nothing yet, sorry
I’ve had similar issues with the audio on DVR recordings. Here is what I’ve been doing to bring it back.
From your Plex Media Server in a browser:
  • Settings
    • Languages
      • Prefer Audio Tracks in “None”
      • Prefer Subtitles in “None”
      • Deselect (Unchecked box) - Automatically select audio and subtitle tracks
        These are to try and force Plex to record all audio tracks available
      • Save Changes
  • Manage
    • Live TV & DVR
      - Delete DVR
On the Plex Media Server
  • Complete any available updates
  • Reboot Plex Media Server
  • Manage
    • Live TV & DVR
      • Add DVR(s)
      • Rescan Channels
Go to the Live TV and check all of the channels that have more than one audio track. If any channel is missing some audio track, repeat the check of all of the channels until no audio tracks are missing.
Try the DVR.
Hopefully, Plex will record all available audio streams and you may have to select the English stream if more than one is available and Plex doesn’t choose the one you want.
  • Playback Settings
    • Audio Stream
      • If more than one audio stream is available, choose the one you want
The best results that I have found is when I make any changes - updates, add files, delete files, etc., I complete them all at once and then go thru this process completely.
Hope this helps!
Dave
