No Library or MyPlex but Channels OK
Sorry in advance for the long Log File. ... I left it running in hopes it would just spring to life.
Been running PlexConnect successfully since May 2013 so it has been configured and running just fine for months.
Last night Windows updated (see latest updates on my system: http://s24.postimg.org/pvx7fqeut/Screenshot_1.png
Today I updated PlexConnect and it shows "Accessing trailers" in Library and MyPlex, Channels is fine. Responses below should help. I have tried my previous version and the newest just to see.
  • Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV3 6.02  ATV2 6.01 (guessing, pregnant wife is using AirPlay right now)
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.7.20
  • The device and operating system (including version number) that PlexConnect is installed on: Windows 8
  • The local IP address of the device that PlexConnect is installed on: ATV3 192.168.7.13; ATV2 192.168.7.27
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on: Windows 8 running PMS with Python 2.7 (with both allowed to communicate through the firewall).
  • The Plex media server (PMS) version number you are running (do not put 'latest'): 0.9.8.5
  • The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.7.20
  • The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one. 095212fa4924f15652a2f767eca696cc0c73ab50 downloaded 11.16.2013 from Github as zip file.
  • The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
[PlexConnect]
enable_webserver_ssl = True
logpath = N:\Users\Will\Desktop\Old Plex Connect
enable_dnsserver = True
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = N:\Users\Will\Desktop\PlexConnect-master 20131116\assets\certificates railers.pem
ip_dnsmaster = 192.168.7.1
loglevel = High (normally Normal)
ip_pms = 192.168.7.20
enable_plexgdm = True (normally False but trying things from other posts)
port_ssl = 443
  • Detail on the media file if it is an issue related to playing a media file: None. Accessing Trailers on Library and MyPlex. Channels works perfectly.
  • detailed description of the issue (the clearer you can make this the better): Woke up to a rebooted PC running Windows 8. No problem, happens. Fired up PlexConnect and nothing from Library or MyPlex. Channels worked fine. Updated to latest commit and same thing. v0.2 same thing. Plex works fine from iPad/iPhone to aTV using AirPlay.
  • Ensure you post your 'PlexConnect.log' file to pastebin and post the link ('PlexConnect.log' is located in your PlexConnect folder). If possible, follow these steps to create a "more detailed fresh" one: http://pastebin.com/TGbB54jk
Problem fixed with the Nov 16, 2013 11:30 am commit.
f47a77e0318689bb23262326f4221f0d25fd1db3
Thanks!!!
I am glad your issue was solved so quickly. Even without knowing about it... :-D
How did you solve it exactly?
Everything was working (last git pull from ~ 8 days ago), then I did a pull this morning and encountered the same error afterwards ("accessing trailers", the channels were there though).
I pulled again a few minutes ago and PlexAPI.py was refreshed, but all the same
Honestly, I haven't looked into this issue in detail, as it was solved before I saw it. :-D
Could you please post logs - they are needed to figure out whats wrong. It probably is best to start a new thread with your issues.
nevermind. The latest version is not working for me as I still have the same error / behavior as described by SactoWillyZ.
As I don't have much time atm, I did a git reset to ffe1a30a68bd5c7ff92ad0c5d92c989017c8b441 and it is working again
I'll look into it later
Hi everyone, a newbie here :) Is everyone talking about the MyPlex Queue (where you can add videos on a computer and watch on Plex)? I just setup aTV3 with PlexConnect and it's awesome! Everything works except for MyPlex. I get "No Plex Library Sections Available". I tried master and f47a77e0318689bb23262326f4221f0d25fd1db3 sha. Should I rollback to some earlier known sha or is it not working for everyone?
Thanks, guys!
We are NOT talking about MyPlex Queue. It's all about MyPlex server sharing.
The Queue is NOT implemented... we are planning in offering queue access via PMS plugin.
