No Library or MyPlex but Channels OK
  • Your ATV model (2 or 3) and firmware version: ATV 3 User-Agent: iTunes-AppleTV/6.0.2 (3; 8GB; dt:12), Model MD199L/A, OS 6.0.2 (6646.81.1)
  • The DNS server set on the ATV: 10.0.1.8
  • The device and operating system (including version number) that PlexConnect is installed on: 2007 Dell Latitude D620, Ubuntu Server 12.04.3 LTS (GNU/Linux 3.2.0-56-generic-pae i686)
  • The local IP address of the device that PlexConnect is installed on: 10.0.1.8
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on: Same as PlexConnect machine
  • The Plex media server (PMS) version number you are running (do not put 'latest'): Version 0.9.7.22
  • The local IP address of the device that the Plex media server (PMS) is installed on: 10.0.1.8
  • The PlexConnect version number: GitHub pulled 11/18/2013 @ 6:08 PM
  • The content of your 'Settings.cfg' file: http://pastebin.com/GRKcTHXx
  • detailed description of the issue: As a previous poster had mentioned (http://forums.plexapp.com/index.php/topic/86475-no-library-or-myplex-but-channels-ok/) Local and MyPlex libraries hang on "Loading Trailers" but Channels and Settings load fine. Opening a channel shows "Trailers Unavailable. Try again later".
  • PlexConnect Log: http://pastebin.com/SiDFKvGB
THIS FIXED IT FOR ME!!! (http://forums.plexapp.com/index.php/topic/85747-working-plexconnect-broke-with-one-of-the-newer-commits/)
