No longer able to filter episodes on Collection
Server Version#: 1.21.4.4079
Player Version#: not applicable, it’s on all clients
I have added a collection to multiple shows in my library. I then opened the Episodes view, sorted the episodes on air date and added a filter on the collection and the shown status. Afterwards I created a playlist based on this view. This playlist existed for a few years now, I have been using it for a very long time to make sure I saw all episodes in the right order as sometimes the stories of the different shows overlapped.
This weekend I wanted to look at the newest episodes in my playlist and to my surprise I noticed it was empty, I’m 100% sure there are new episodes that I still have to watch. I haven’t opened the playlist in a few months now so I’m not 100% sure since when this issue exists.
When I try to edit my existing playlist it throws an error that I can’t edit it.
So I opened the episodes view again, but as soon as I filter the episodes on one collection, Plex says there are no items matching my filter. I verified that the collection is still correctly set on my shows, so that’s not the issue either.
You can’t use the quick filter ‘Collection’ when you are in the ‘Episodes’ view mode. Because the quick filters only contains filters which are available at the episode level – which is not true for collections, which can only be added to a show, but not to episodes.
Try to build the filter using the “Show Collection” from the “custom filters”.
Thanks a lot! That one is working indeed. Do you know why this behavior has changed? My existing playlist worked fine for more than 2 years :slight_smile:
AFAIK, because the filters were re-specified stricter, as I mentioned above.
The collection quickfilter shouldn’t even appear anymore when in Episodes view mode.
I recommend you to delete the old smart playlist and create a new one according to the above instructions.
That’s what I did now. :slight_smile:
I’m really glad you were able to help me out so fast. :slight_smile:
Luckily the Plex Moderators reply faster than Plex Staff :smiley:
