Any Idea whats going on here? seems PMS dies after this with no crash log. There is a 1080ti locally as well as a Vega 64 FE
Mar 30, 2018 22:47:01.739 [51848] ERROR - [FFMPEG] - OpenEncodeSessionEx failed: out of memory (10)
Mar 30, 2018 22:47:01.786 [51848] ERROR - [FFMPEG] - No NVENC capable devices found
Mar 30, 2018 22:47:01.786 [51848] WARN - avcodec_open2 returned -542398533 for encoder 'h264_nvenc'
Mar 30, 2018 22:47:02.531 [56648] ERROR - Unable to find client profile for device; platform=Opera TV Store, platformVersion=0, device=, model=
Mar 30, 2018 22:47:03.546 [51848] INFO - [FFMPEG] - MFT name: 'NVIDIA H.264 Encoder MFT'
Mar 30, 2018 22:47:03.731 [53068] ERROR - [FFMPEG] - OpenEncodeSessionEx failed: invalid version (15)
Mar 30, 2018 22:47:03.794 [53068] ERROR - [FFMPEG] - No NVENC capable devices found
Mar 30, 2018 22:47:03.794 [53068] WARN - avcodec_open2 returned -542398533 for encoder 'h264_nvenc'
Mar 30, 2018 22:47:05.124 [51848] ERROR - [FFMPEG] - OpenEncodeSessionEx failed: invalid version (15)
Mar 30, 2018 22:47:05.208 [51848] ERROR - [FFMPEG] - No NVENC capable devices found
Mar 30, 2018 22:47:05.208 [51848] WARN - avcodec_open2 returned -542398533 for encoder 'h264_nvenc'
Mar 30, 2018 22:47:05.240 [53068] INFO - [FFMPEG] - MFT name: 'NVIDIA H.264 Encoder MFT'
Mar 30, 2018 22:47:06.852 [51848] ERROR - [FFMPEG] - could not create MFT
Mar 30, 2018 22:47:06.852 [51848] WARN - avcodec_open2 returned -40 for encoder 'h264_mf'
Mar 30, 2018 22:47:07.824 [53068] ERROR - [FFMPEG] - OpenEncodeSessionEx failed: out of memory (10)
Mar 30, 2018 22:47:07.886 [53068] ERROR - [FFMPEG] - No NVENC capable devices found
Mar 30, 2018 22:47:07.886 [53068] WARN - avcodec_open2 returned -542398533 for encoder 'h264_nvenc'
Mar 30, 2018 22:47:08.703 [54444] WARN - Took too long (0.281250 seconds) to start a transaction on ..\Library\MetadataItem.cpp:6965
Mar 30, 2018 22:47:08.703 [54444] WARN - Transaction that was running was started on thread 56484 at ..\Library\MetadataItem.cpp:929
Mar 30, 2018 22:47:09.044 [51848] ERROR - [FFMPEG] - CreateBitstreamBuffer failed: invalid version (15)
Mar 30, 2018 22:47:09.922 [53068] INFO - [FFMPEG] - MFT name: 'NVIDIA H.264 Encoder MFT'
Mar 30, 2018 22:47:10.239 [53068] ERROR - [FFMPEG] - could not set output type (MF_E_UNSUPPORTED_D3D_TYPE)
Mar 30, 2018 22:47:10.239 [53068] WARN - avcodec_open2 returned -542398533 for encoder 'h264_mf'
Mar 30, 2018 22:47:56.155 [57472] ERROR - [Transcoder] [h264_nvenc @ 042cec80] OpenEncodeSessionEx failed: out of memory (10)
Mar 30, 2018 22:47:56.202 [57472] ERROR - [Transcoder] [h264_nvenc @ 042cec80] No NVENC capable devices found
Mar 30, 2018 22:47:56.202 [5436] ERROR - [Transcoder] Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
Mar 30, 2018 22:48:08.904 [58196] ERROR - Error issuing curl_easy_perform(handle): 56
Mar 30, 2018 22:48:08.904 [58196] WARN - HTTP error requesting GET http://192.168.115.2:8200/rootDesc.xml (0, No error) (Recv failure: Connection was reset)
Mar 30, 2018 22:48:27.354 [46244] WARN - Transcode runner appears to have died.
PMS: 1.12.1.4885
Boysie
