No Nvidia P400 decode acceleration with 1.17.0.1709
Server Version#: 1.17.0.1709
Player Version#: PlexWeb 4.8.1
OS Version: Windows 10 1809
With the recent transcoder update in 1709, PMS is no longer using acceleration for decoding. Encoding still mostly works. I’ve tested this with HEVC, AVC, and MPEG2.
Prior to the new update, the transcoder was working fine for both encode and decode. I can’t guarantee it’s the new update, but it was the only change. I tried to fix it with a display driver update, but it had no effect. I haven’t reverted yet to to do further testing.
I tossed in a sample of my logs here, I could PM them privately if needed.
Is this problem specific to me, or if this is a known problem with the current release?
[I had to remove some repeated sections of “testing API” for nvenc and nvdec. I hit the character limit. The basics are there, sorry.]
Sep 26, 2019 15:11:02.387 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): Direct Play is disabled
Sep 26, 2019 15:11:02.387 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): media must be transcoded in order to use the dash protocol
Sep 26, 2019 15:11:02.387 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): no direct play video profile exists for http/mkv/h264
Sep 26, 2019 15:11:02.387 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): no direct play video profile exists for http/mkv/h264/dca
Sep 26, 2019 15:11:02.387 [1612] DEBUG - Close Encounters of the Third Kind (Director's Cut) - video.bitrate limitation applies: 22857 > 2000
Sep 26, 2019 15:11:02.387 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): Direct Streaming is disabled, so video stream will be transcoded
Sep 26, 2019 15:11:02.387 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): no remuxable profile found, so video stream will be transcoded
Sep 26, 2019 15:11:02.387 [1612] DEBUG - Codecs: testing h264_nvenc (encoder)
Sep 26, 2019 15:11:02.387 [1612] DEBUG - Codecs: hardware transcoding: testing API nvenc
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded lib: nvcuda.dll
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuInit
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetCount
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetAttribute
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetName
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceComputeCapability
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxCreate_v2
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxSetLimit
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxPushCurrent_v2
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxPopCurrent_v2
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxDestroy_v2
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemAlloc_v2
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemAllocPitch_v2
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemsetD8Async
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemFree_v2
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemcpy2D_v2
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemcpy2DAsync_v2
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGetErrorName
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGetErrorString
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamCreate
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamQuery
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamSynchronize
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamDestroy_v2
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamAddCallback
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventCreate
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventDestroy_v2
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventSynchronize
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventQuery
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventRecord
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuLaunchKernel
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuModuleLoadData
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuModuleUnload
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuModuleGetFunction
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuTexObjectCreate
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuTexObjectDestroy
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGLGetDevices_v2
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsGLRegisterImage
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsUnregisterResource
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsMapResources
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsUnmapResources
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsSubResourceGetMappedArray
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetUuid
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuImportExternalMemory
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDestroyExternalMemory
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedBuffer
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedMipmappedArray
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMipmappedArrayGetLevel
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMipmappedArrayDestroy
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuImportExternalSemaphore
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDestroyExternalSemaphore
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuSignalExternalSemaphoresAsync
Sep 26, 2019 15:11:02.387 [1612] DEBUG - [FFMPEG] - Loaded sym: cuWaitExternalSemaphoresAsync
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded lib: nvcuda.dll
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuInit
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetCount
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetAttribute
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetName
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceComputeCapability
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxCreate_v2
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxSetLimit
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxPushCurrent_v2
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxPopCurrent_v2
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxDestroy_v2
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemAlloc_v2
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemAllocPitch_v2
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemsetD8Async
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemFree_v2
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemcpy2D_v2
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemcpy2DAsync_v2
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGetErrorName
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGetErrorString
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamCreate
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamQuery
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamSynchronize
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamDestroy_v2
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamAddCallback
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventCreate
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventDestroy_v2
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventSynchronize
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventQuery
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventRecord
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuLaunchKernel
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuModuleLoadData
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuModuleUnload
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuModuleGetFunction
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuTexObjectCreate
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuTexObjectDestroy
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGLGetDevices_v2
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsGLRegisterImage
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsUnregisterResource
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsMapResources
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsUnmapResources
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsSubResourceGetMappedArray
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetUuid
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuImportExternalMemory
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDestroyExternalMemory
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedBuffer
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedMipmappedArray
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMipmappedArrayGetLevel
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMipmappedArrayDestroy
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuImportExternalSemaphore
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDestroyExternalSemaphore
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuSignalExternalSemaphoresAsync
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: cuWaitExternalSemaphoresAsync
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded lib: nvEncodeAPI.dll
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: NvEncodeAPICreateInstance
Sep 26, 2019 15:11:02.450 [1612] DEBUG - [FFMPEG] - Loaded sym: NvEncodeAPIGetMaxSupportedVersion
Sep 26, 2019 15:11:02.543 [1612] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Sep 26, 2019 15:11:02.543 [1612] DEBUG - Codecs: hardware transcoding: testing API nvdec
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded lib: nvcuda.dll
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuInit
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetCount
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetAttribute
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetName
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceComputeCapability
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxCreate_v2
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxSetLimit
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxPushCurrent_v2
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxPopCurrent_v2
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuCtxDestroy_v2
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemAlloc_v2
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemAllocPitch_v2
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemsetD8Async
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemFree_v2
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemcpy2D_v2
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMemcpy2DAsync_v2
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGetErrorName
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGetErrorString
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamCreate
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamQuery
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamSynchronize
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamDestroy_v2
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuStreamAddCallback
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventCreate
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventDestroy_v2
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventSynchronize
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventQuery
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuEventRecord
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuLaunchKernel
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuModuleLoadData
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuModuleUnload
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuModuleGetFunction
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuTexObjectCreate
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuTexObjectDestroy
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGLGetDevices_v2
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsGLRegisterImage
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsUnregisterResource
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsMapResources
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsUnmapResources
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuGraphicsSubResourceGetMappedArray
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDeviceGetUuid
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuImportExternalMemory
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDestroyExternalMemory
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedBuffer
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedMipmappedArray
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMipmappedArrayGetLevel
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuMipmappedArrayDestroy
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuImportExternalSemaphore
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuDestroyExternalSemaphore
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuSignalExternalSemaphoresAsync
Sep 26, 2019 15:11:02.543 [1612] DEBUG - [FFMPEG] - Loaded sym: cuWaitExternalSemaphoresAsync
Sep 26, 2019 15:11:02.637 [1612] DEBUG - Scaled up video bitrate to 34285Kbps based on 1.500000x fudge factor.
Sep 26, 2019 15:11:02.637 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): Audio Direct Streaming is disabled, so video's audio stream will be transcoded
Sep 26, 2019 15:11:02.637 [1612] DEBUG - Codecs: testing aac_mf (encoder)
Sep 26, 2019 15:11:02.637 [1612] INFO - [FFMPEG] - MFT name: 'Microsoft AAC Audio Encoder MFT'
Sep 26, 2019 15:11:02.684 [1612] DEBUG - MDE: Cannot direct stream audio stream due to profile or setting limitations
Sep 26, 2019 15:11:02.684 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): selected media 0 / 45188
Sep 26, 2019 15:11:02.684 [1612] DEBUG - Streaming Resource: Calculated bandwidth of 2369kbps exceeds bandwidth limit. Changing decision parameters provided by client to fit bandwidth limit of 2000kbps
Sep 26, 2019 15:11:02.684 [1612] DEBUG - Streaming Resource: Determining preferred transcode encoders through transcode only decision.
Sep 26, 2019 15:11:02.684 [1612] DEBUG - Codecs: testing h264_nvenc (encoder)
*["testing API" nvenc and nvdec sections removed]*
Sep 26, 2019 15:11:02.918 [1612] DEBUG - Scaled up video bitrate to 34285Kbps based on 1.500000x fudge factor.
Sep 26, 2019 15:11:02.918 [1612] DEBUG - Codecs: testing aac_mf (encoder)
Sep 26, 2019 15:11:02.918 [1612] INFO - [FFMPEG] - MFT name: 'Microsoft AAC Audio Encoder MFT'
Sep 26, 2019 15:11:02.965 [1612] DEBUG - Codecs: testing h264_nvenc (encoder)
Sep 26, 2019 15:11:03.184 [1612] DEBUG - Scaled up video bitrate to 34285Kbps based on 1.500000x fudge factor.
Sep 26, 2019 15:11:03.184 [1612] DEBUG - Codecs: testing aac_mf (encoder)
Sep 26, 2019 15:11:03.184 [1612] INFO - [FFMPEG] - MFT name: 'Microsoft AAC Audio Encoder MFT'
Sep 26, 2019 15:11:03.246 [1612] DEBUG - Streaming Resource: Reducing playback quality for 1904kbps stream bitrate: video resolution to 720x406, audio channels to 2, quality to 41
Sep 26, 2019 15:11:03.246 [1612] DEBUG - Codecs: testing h264_nvenc (encoder)
Sep 26, 2019 15:11:03.481 [1612] DEBUG - Scaled up video bitrate to 34285Kbps based on 1.500000x fudge factor.
Sep 26, 2019 15:11:03.481 [1612] DEBUG - Scaled maximum bitrate for resolution reduction to 4833Kbps.
Sep 26, 2019 15:11:03.481 [1612] DEBUG - Codecs: testing aac_mf (encoder)
Sep 26, 2019 15:11:03.496 [1612] INFO - [FFMPEG] - MFT name: 'Microsoft AAC Audio Encoder MFT'
Sep 26, 2019 15:11:03.543 [1612] DEBUG - MDE: Selected protocol dash; container: mp4
Sep 26, 2019 15:11:03.543 [1612] DEBUG - MDE: analyzing media item 45188
Sep 26, 2019 15:11:03.543 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): Direct Play is disabled
Sep 26, 2019 15:11:03.543 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): media must be transcoded in order to use the dash protocol
Sep 26, 2019 15:11:03.543 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): no direct play video profile exists for http/mkv/h264
Sep 26, 2019 15:11:03.543 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): no direct play video profile exists for http/mkv/h264/dca
Sep 26, 2019 15:11:03.543 [1612] DEBUG - Close Encounters of the Third Kind (Director's Cut) - video.bitrate limitation applies: 22857 > 2000
Sep 26, 2019 15:11:03.543 [1612] DEBUG - Close Encounters of the Third Kind (Director's Cut) - audio.channels limitation applies: 6 > 2
Sep 26, 2019 15:11:03.543 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): Direct Streaming is disabled, so video stream will be transcoded
Sep 26, 2019 15:11:03.543 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): no remuxable profile found, so video stream will be transcoded
Sep 26, 2019 15:11:03.543 [1612] DEBUG - Codecs: testing h264_nvenc (encoder)
Sep 26, 2019 15:11:03.668 [1612] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Sep 26, 2019 15:11:03.668 [1612] DEBUG - Codecs: hardware transcoding: testing API nvdec
[Testing Removed]
Sep 26, 2019 15:11:03.778 [1612] DEBUG - Scaled up video bitrate to 34285Kbps based on 1.500000x fudge factor.
Sep 26, 2019 15:11:03.778 [1612] DEBUG - Scaled maximum bitrate for resolution reduction to 4833Kbps.
Sep 26, 2019 15:11:03.778 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): Audio Direct Streaming is disabled, so video's audio stream will be transcoded
Sep 26, 2019 15:11:03.778 [1612] DEBUG - Codecs: testing aac_mf (encoder)
Sep 26, 2019 15:11:03.778 [1612] INFO - [FFMPEG] - MFT name: 'Microsoft AAC Audio Encoder MFT'
Sep 26, 2019 15:11:03.824 [1612] DEBUG - MDE: Cannot direct stream audio stream due to profile or setting limitations
Sep 26, 2019 15:11:03.824 [1612] DEBUG - MDE: Close Encounters of the Third Kind (Director's Cut) (1977): selected media 0 / 45188
Sep 26, 2019 15:11:03.824 [1612] DEBUG - Streaming Resource: Adding session 0x9da0790:pkfewjyfsqai18nfb06i6t4p which is using transcoder slot.  Used slots is now 1
Sep 26, 2019 15:11:03.824 [1612] DEBUG - Streaming Resource: Added session 0x9da0790:pkfewjyfsqai18nfb06i6t4p
Sep 26, 2019 15:11:03.824 [1612] DEBUG - Streaming Resource: Reached Decision id=13749 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=45188 part=(id=45670 decision=transcode container=mp4 protocol=dash streams=(Video=(id=113065 decision=transcode bitrate=1724 encoder=h264_nvenc width=720 height=406) Audio=(id=113066 decision=transcode bitrate=162 encoder=aac_mf channels=2 rate=48000))))
Sep 26, 2019 15:11:03.824 [10124] DEBUG - Completed: [x.x.x.x:61772] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F13749&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=0&subtitleSize=100&audioBoost=100&location=lan&maxVideoBitrate=2000&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=0&mediaBufferSize=102400&session=lm2sd3aj2pqlks9p4wx02h0w&subtitles=burn&Accept-Language=en (13 live) TLS GZIP 1901ms 4752 bytes (pipelined: 14)
Sep 26, 2019 15:11:04.059 [10124] DEBUG - Auth: authenticated user 1 as Cafe Diem
Sep 26, 2019 15:11:04.059 [1648] DEBUG - Request: [x.x.x.x:61772 (Allowed Network (Subnet))] GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F13749&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=0&subtitleSize=100&audioBoost=100&location=lan&maxVideoBitrate=2000&addDebugOverlay=0&autoAdjustQuality=1&directStreamAudio=0&mediaBufferSize=102400&session=lm2sd3aj2pqlks9p4wx02h0w&subtitles=burn&Accept-Language=en (13 live) TLS GZIP Signed-in Token (Cafe Diem)
Sep 26, 2019 15:11:04.059 [1648] DEBUG - Found session GUID of lm2sd3aj2pqlks9p4wx02h0w in session start.
Sep 26, 2019 15:11:04.059 [1648] DEBUG - TranscodeUniversalRequest: using augmented profile Web
Sep 26, 2019 15:11:04.059 [1648] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/13749?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=pkfewjyfsqai18nfb06i6t4p
Sep 26, 2019 15:11:04.074 [1648] DEBUG - Auth: authenticated user 1 as Cafe Diem
Sep 26, 2019 15:11:04.074 [1648] DEBUG - It took 0.000000 ms to retrieve 122 items.
Sep 26, 2019 15:11:04.074 [1648] DEBUG - We're going to try to auto-select an audio stream for account 1.
Sep 26, 2019 15:11:04.074 [1648] DEBUG - Selecting best audio stream for part ID 45670 (autoselect: 1 language: en)
Sep 26, 2019 15:11:04.074 [1648] DEBUG - We're going to try to auto-select a subtitle.
Sep 26, 2019 15:11:04.074 [1648] DEBUG - Audio Stream: 113066, Subtitle Stream: -1
Sep 26, 2019 15:11:04.090 [1648] DEBUG - Found session GUID of lm2sd3aj2pqlks9p4wx02h0w in session start.
Sep 26, 2019 15:11:04.090 [1648] DEBUG - Cleaning directory for session lm2sd3aj2pqlks9p4wx02h0w ()
Sep 26, 2019 15:11:04.090 [1648] DEBUG - Starting a transcode session lm2sd3aj2pqlks9p4wx02h0w at offset -1.0 (state=3)
Sep 26, 2019 15:11:04.090 [1648] DEBUG - TPU: hardware transcoding: using hardware decode accelerator nvdec
Sep 26, 2019 15:11:04.090 [1648] DEBUG - [Universal] Using local file path instead of URL: F:\Movies\Close Encounters of the Third Kind (1977) (Director's Cut).mkv
Sep 26, 2019 15:11:04.090 [1648] DEBUG - TPU: hardware transcoding: zero-copy support not present
Sep 26, 2019 15:11:04.090 [1648] DEBUG - TPU: hardware transcoding: final decoder: nvdec, final encoder: nvenc
Recent topics similar to yours consistently ask the user to get the newly released NVIDIA driver. Users reported success with the one supplied though Windows Update and not the one that you get from NVIDIA’s website.
Any luck?
Even with a forum search, I somehow missed those. Thanks, I’ll give it a shot later today.
The post was a cryptic one liner from a phone with spelling errors :crazy_face:
It’s in the release note.
Note: Hardware transcoding with Nvidia GPUs now requires driver v418.30 or newer
I’m nearly sure my drivers were newer than that, but I’ll run some more tests later this afternoon. I honestly missed that note, so thanks.
Ok, I think I’m set now. This seems to have been the resolution to this for me:
  1. I updated the OS to the latest version of Windows and removed all existing Nvidia drivers.
  2. On Windows 10 1903 with the basic driver, it still didn’t work. (Windows Update didn’t offer any newer driver)
  3. I updated the driver to the latest WHQL from Nvidia (clean installation) and it started working. Woo hoo.
I had installed that same driver under the prior Windows version, and it didn’t work. No idea why it worked the second time, but here we are.
In a related note, I realized that Tautulli was not properly reflecting the hardware acceleration status, which also threw me for a loop during testing. I wrote that up separately. Thanks for everyone’s help!
Hey @anon18523487 Thanks for this info.
What about those of us with older video cards? When I try to playback live tv with Hardware acceleration on, PMS crashes.
Nov 11, 2019 10:41:16.452 [12312] INFO - Notification: Recording Live TV - Session -
Nov 11, 2019 10:41:17.747 [13720] WARN - [FFMPEG] - Encoder will work with partial HW acceleration
Nov 11, 2019 10:41:17.751 [13720] ERROR - [FFMPEG] - Error initializing the encoder: invalid video parameters (-15)
Nov 11, 2019 10:41:17.762 [13720] WARN - Codecs: avcodec_open2 returned -22 for encoder 'h264_qsv'
Nov 11, 2019 10:41:18.100 [13720] ERROR - [FFMPEG] - Cannot load nvEncodeAPI.dll
Nov 11, 2019 10:41:18.100 [13720] ERROR - [FFMPEG] - The minimum required Nvidia driver for nvenc is 418.81 or newer
Nov 11, 2019 10:41:18.109 [13720] WARN - Codecs: avcodec_open2 returned -1 for encoder 'h264_nvenc'
Nov 11, 2019 10:41:18.510 [13720] INFO - [FFMPEG] - MFT name: 'Intel� Quick Sync Video H.264 Encoder MFT'
The nVidia site says the latest drivers for my card (GTX 460) are v391.35 . I have tried installing a new driver, but the installer says it’s not applicable to my system.
I tried removing all drivers and going with what Windows supplied but that numbering convention is completely different. 23.21.13.9135 Yes it is still an old driver and I have tried several times to but Windws Updates says it’s the latest. image
Your help is appreciated. Right I’m resorting to disabling hardware acceleration.
gtx460 is too old and doesn’t support any hw transcoding.
Video Encode and Decode GPU Support Matrix | NVIDIA Developer
Thanks @TeknoJunky That certainly clears this up.
