I deleted my TV show library by accident, so i created a new one but to of my TV show are recognized without any poster : Marvel’s Defender and MINDHUNTER.
Yup, having the same issue with a few newly added shows. It will probably be resolved in due time, so I’ll just live with a few missing posters for now
First: Synology is normally slow to match. It’s a small processor.
Second, but most important, TheTVDB has issues with Banners (Posters) in their API. There’s nothing we can magically do at the plex.tv site as an instant correction because they have the images everyone needs.
Work-around: Go into “Fix Match” and change the agent to TMDB. It will match that Series to TMDB and you’ll get all your posters once the series itself is paired with TMDB.
Tertiary:
Engineering is putting together a more intelligent mechanism (there is already more than one source for posters). Fingers crossed but so far so good and hope we’ll see it soon.
As already said in this thread, it’s due to thetvdb.org having problems, and as such, out of control for Plex.
All we can recommend, is either make sure that your scheduled tasks are running, since due to that, it will catch up sooner or later, or manually refresh from time to time
@ddanielww said:
STILL IS STILL AN ISSUE, NO ARTWORK GETS ADDED!
Directory and Filenames exactly as you have them please?
As stated in MANY posts . Perform a manual match switching to TMDB for the manual match. When you do, it will pull metadata and image from TMDB.
This is the workaround until TheTVDB gets their API and internal problems with file permissions on their directories resolved.
Reiterating Dane22, There is no need to shout. Those of us who monitor the forum get every single post made. Depending on the volume, we may or may not be able to reply immediately
I did a bit of digging in the plex agent logs, as plex can’t grab posters, but gets the info.
Sonarr grabs both things right.
What i noted was this:
I am using Succession (2018) as an example. 2018-06-05 13:06:09,278 (7f31f0ff9700) : DEBUG (networking:166) - Requesting 'https://thetvdb.com/banners/episodes/338186/6666566.jpg'
Grabbing episode poster, success.
