No posters from cinematerial
Server Version#: 1.19.1.2589
Player Version#: Web app
Plex appears not to be getting any posters from cinematerial at all, only themoviedb. All other metadata is populating correctly, so it doesn’t seem to be naming.
I tried doing the plex dance, I have deleted the caches and data folders of the plugin support folder, and refreshed, no help.
I have plex movie selected as the agent for the library, and the agents configured as below:
I noticed that the data folder doesn’t have a subfolder for cinematerial, only movieposterdb.com.plexapp.agents.movieposterdb.log (251.3 KB)
Okay, now even more issues. Lots of stuff in this and other libraries is not finding metadata at all.
westworld
Folders are correct, Westworld/Season 1/Westworld S01E01. I cannot refresh metadata, if I use fix match, it does nothing, if I unmatch and fix match, nothing.
I noticed when trying to change the metadata agent, that the folder is gone, but I can still play anything in the library, I added the folder again and refreshed metadata, but nothing.
Edit, I believe this is just due to Tvdb2.plex.tv being down right now, so that’s fine, but my cinematerial post still remains.
