No remote access
Server Version 4.12.3
Player Version any external
i can’t activate the remote access.
It goes for a short green then he switch back to red.
I try it also with deactivated firewall on the router and windows at the same time.
IPv6 is deaktivated also on networkcard also in plex and router.
Sign in Plex, i can see my name in the left corner.
Any idea what i can do?
Best regards,
Christof
Just for confirmation…
Do you rely on the remote access status indicator within Plex Web or did you actually try to play some content while outside your home network? The indicator has a tendency to be out-of-sync.
If you cannot access your server from outside your home network…
Have you checked if your router supports UPnP or did you setup a dedicated port-forward for your Plex Media Server?
Hey Tom,
yes, i mean the status indicator in the Plex Webinterface.
The Windows Server is connected to the web and on my android phone the plex app show me the server as offline.
UPnP is activated and i also try it with port forwarding
Can you ping/reach the public IP address of your router via the TCP port used by Plex (32400) or the port you defined in your port forward?
You can check this e.g. with a service like canyouseeme.org
For me the same.
Using intern 32400 port and the same port for external.
Port forwarding 32400 to the server in the router.
https://www.canyouseeme.org/ told there are nothing…
A test with this page to my ftp server works fine…
It looks like there is no software how answer the external task.
sorry for moving your post… I just want to avoid people from jumping the “me too” bandwagon.
Is your port forward currently active?
If it is and you still cannot reach your router, you should contact your ISP to ask them if they might be blocking that port and if they could unblock it for you.
Follow the steps below:
  • Open command-prompt with admin privileges;
  • Run the command: netsh advfirewall firewall add rule name="Plex Server" dir=in action=allow protocol=TCP localport=32400
  • Uncheck “Manually specify public port”;
  • Disable remote access;
  • Enable remote access.
I might have misread some part of your post…
Not sure this is going to help if the user already has issues to even access his/her router from outside their home network. Aren’t you just adding a firewall rule to your local Windows machine?
Exactly. When the user creates a port forwarding to their server and they test the connection with canyouseeme , the website connection test will pass through the router and reach the server. If the door is closed on the server, the website will have their connection dropped, and if the application Plex is down, the website will receive a reject tcp response.
All the cases where the users describe as “work for a few seconds” the problem was in their server, at least the ones I helped to fix.
Hello Costa,
ist try your dos command, it say ok, but still don’t work.
I am disable the firewall in the router (Exposed Host ipv4 and ipv6) and also the firewall in windows.
port forwaring in the router for ipv4 and ipv6 fpr 32400. tcpip (fritzbox) is green
plex media runs in internal network well
also i can connect from extern my ftp server:
Success: I can see your service on **** on port ( 21 )
Error: I could not see your service on **** on port ( 32400 )
Reason: No route to host
ipv4 and ipv6 are enable in networkcard and in plex network
That leaves us with…
