No response from webserver ?
PlexConnect seems to be working ok, until I want to play something.
PMS is running just fine (on a Synology NAS)
Any idea what the cause could be ?
19:45:58 WebServer: ***
19:45:58 PlexGDM: ***
19:45:58 PlexGDM: looking up Plex Media Server
19:45:58 WebServer: started: 19:45:58
19:45:58 WebServer: WebServer: Serving HTTPS on 10.0.0.40 port 443.
19:45:59 PlexGDM: servers discovered: 1
19:45:59 XMLConverter: PlexGDM - PMS: 10.0.0.40:32400
19:47:14 DNSServer: DNS request received!
19:47:14 DNSServer: Source: ('10.0.0.8', 52995)
19:47:14 DNSServer: Domain: trailers.apple.com
19:47:14 DNSServer: ***intercept request
19:47:14 DNSServer: -> DNS response: 10.0.0.40
19:47:14 DNSServer: Source: ('10.0.0.8', 52946)
19:47:15 WebServer: serving application.js
19:47:15 DNSServer: DNS request received!
19:47:15 DNSServer: Source: ('10.0.0.8', 59679)
19:47:15 DNSServer: Domain: atv.plexconnect
19:47:15 DNSServer: ***intercept request
19:47:15 DNSServer: -> DNS response: 10.0.0.40
19:47:15 DNSServer: Source: ('10.0.0.8', 58614)
19:47:15 WebServer: serving .xml: /PlexConnect.xml
19:47:15 WebServer: serving  /volume1/@appstore/plexconnect/share/PlexConnect/assets/js/utils.js
19:47:15 WebServer: serving .xml: /library/sections
19:47:16 WebServer: serving .xml: /library/sections/1/recentlyAdded
19:47:20 WebServer: serving .xml: /webdefault/sample.php
19:47:20 XMLConverter: HTTP response error: 404 Not Found
19:47:20 XMLConverter: No Response from Plex Media Server
Please provide all of the info requested in the Read Before Posting thread stickied at the top of the forum.
What PlexConnect branch?
I am using your master branch, did a git pull last night (after your code cleanup)
PMS v0.9.7.28
Strangely enough:
When I use "directplay" - I get the error - content not available (on atv) with the error in the log shown above.
When I use "transcode" - it plays but with a lot of buffering (as expected - on synology 1511+ is serving, not enough power)
When I use "auto" - it plays very well, except that there are no subtitles shown, although I can select a subtitle.
You still haven’t provided enough info about your setup. Please do so.
At this point, I would suggest updating PMS to newest public build (9.8.6, I believe). 9.7.28 has known issues with channels, but more info would let us diagnose fully.
