Not able to create music lib without a pass?
Help!!
hi there,
I already placed this on Facebook and plex advised me to post this problem om the forum. so here it is :wink:
i have a strange problem
i started with plex last month on my nvidia shield with a synolgy nas as storage for my media. So latest android version of plex is used.
1 added a tv series library (with Sonarr in the background) and this works great
2 added a movie library (with couch patato in the backgrond and also works great
Now the problem started, i created a music library and added a map with just one MP3 album. No entries are found! so i did a manual scan and then a popup is saying that i need a plex pass to do a scan !?!?!
i deleted the entire library and created a new on (only def setting are used) added the map with the mp3 album and again no result. i need to have a pass to scan this library.
what is wrong? are you not allowed to create/fill a library without buying a pass?
Anybody familiar with this strange behaivior?
Are you sure you did not downgrade the server software version on your Shield? (Happens if you reset the Shield to factory settings)
Which Plex server software version do you have on it now?
While creating the new music library, did you go into the ‘Advanced’ tab and change the selections for ‘Scanner’ and ‘Agent’? It probably only works if both are set to ‘Plex Music’.
no, i did upgraded to the latest version …
Version 1.18.1.1973
both values are set to plex music (i didnt changed them so they are default)
Which web app are you using while working on that?
I recommend app.plex.tv
That’s the URL I’m using. The strange thing is that it works for every other type of library without any problem. Only the music library gives this problem :frowning: I deleted the lib, created it again and still the message you need a plex passport.
Hm, have you tried to use the local web app instead?
http://ip-of-your-shield:32400/web
Can you share a screenshot of the message you are seeing?
You mean from the website (https://app.plex.tv/desk…) or the error code?
While it is displaying the error code.
this the message after a manual scan started
Verify that your Shield has internet connectivity before starting a library scan. It needs that or it won’t work.
The shield is playing a youtube movie now, started the scan again thru the browser but … still not allowed.
Could you share your server logs after an attempted scan? That error modal is from an older version of the web client and it should only show up if the media server responded with a specific error code.
