Not Available outside my network/Double NAT (wired connection)
Server Version#: 1.40.3.8555
My connection seems to work well for a bit and then just says not available, nothing I do ‘fixes’ it other than to keep hitting RETRY on the connection till it EVENTUALLY works.
I have my library and server on a Mac Studio which is hard wired into the router.
Anu suggestions greatly received. Thanks
Does your ISP provide you a publicly routable IPv4 address? If so have you allowed incoming traffic via TCP port 32400?
Yes have done exactly that
