Not available outside your network
Why is this “Not available outside your network” such a common issue with Plex? We can’t get it to connect and we’re just growing tired of this issue. I notice this issue is throughout your forums. Can I please get a resolution? I’m trying to connect with AT&T BGW210-700 and it’s just a nightmare with this plex issue.
If you haven’t already figured it out… Firewall rules on the bgw210 allowing 32400 to your server (there are instructions everywhere for this) and disable ipv6 on the bgw210. I was able to verify my firewall rules were working and couldn’t figure out why I couldn’t get Plex to work remotely for about two days before trying it with ipv6 disabled. Everything started working instantly when I did that.
Here is a more recent fix for BGW210 remote access issues if you still can’t get it working… AT&T started rolling out a garbage firmware update across the country at the beginning of August that broke port forwarding, and naturally the only fix is to manually downgrade it yourself:
