Remote connection not working
Still no success on getting remote service back anyone able to help???
LOGS Zip file
Im on windows 7,using ATT fiber on a Arris router BGW210-700.
I have tried resetting the router as new, i’m port forwarded iv even gone and tried new ports now (still using 32400 and base port), static IP, Even disabled all firewall (back on now didnt fix the issue, iv done research to no avail. My server was working for months perfectly without issue. This has been going on for about a week now. I have also opened up CMD and ran netstat -a and looks like the ports are’nt listening and when Plex is running there are a tone of ports trying to communicate almost all in the 60000 range i’m not sure if that’s normal or not but i don’t think it is. I have even gone off and downloaded Emby and that doesn’t even want to allow remote connection i’m really not sure what the hell is going on i don’t have a huge knowledge base on a lot of this stuff. I really appriciate any help that is given.
Give my fix a try! It’s all AT&T’s fault :slight_smile:
