Not pulling the right Metadata
Server Version#: Windows Server 4.87.2
Good afternoon, I am having troubles with Plex not pulling the right Metadata from thetvdb, it is taking a “Season 0” episode as the first episode of S06.
And as you can see here, this is how it should be.
I have tried doing the thetvdb-253990 search on Search Options but it still comes back wrong, any tips?
Thank you!
How are the files named? Can you post a screenshot of those files?
This is the Season 6
This is the Specials
Emby picks it up right.
I believe you’re pulling TMDB data
Verify that the library or show is set to use TVDB as the show order
show level (pencil in show poster) -->advanced
Library advanced settings
Thank you! I knew there was a way to change the metadata source, I couldn’t remember for the life of me!
It’s skillfully hidden just enough that you forget where it is by the next time you need it lol
