Not seeing all TV files
So I have a folder with a tv series From the Earth to the Moon. It’s only seeing the last three episodes. The others are names similar with spaces and dashes and match
https://www.thetvdb.com/series/from-the-earth-to-the-moon/seasons/1
Any idea how I can get plex to see the entire folder?
Nothing is in the folder but those files.
similar is not relevant.
It has to be compliant to this:
https://support.plex.tv/articles/200220687-naming-series-season-based-tv-shows/
Please show your used folder and file names.
Do also this before experimenting further:
Go to
  • Settings - Server - Agents - Shows - TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Repeat the same under
  • Settings - Server - Agents - Shows - TheMovieDatabase
  • Settings - Server - Agents - Movies - Plex Movie
  • Settings - Server - Agents - Movies - TheMovieDatabase
After you have renamed folders and files to be compliant, perform the Plex Dance.
