Not seeing DVR recording season breakouts in interface
Server Version#: Ubuntu 19.10 (1.20.1.3252-a78fef9a9)
Player Version#: Safari 4.42.1
Tuner 1: HDHomeRun CONNECT DUO
Tuner 2: HDHomeRun CONNECT QUATTRO
When recording shows they are organized correctly on my storage:
ls /media/video/tv/The\ Big\ Bang\ Theory\ (2007)/*
/media/video/tv/The Big Bang Theory (2007)/Season 01:
The Big Bang Theory (2007) - S01E04 - The Luminous Fish Effect.ts
The Big Bang Theory (2007) - S01E05 - The Hamburger Postulate.ts
The Big Bang Theory (2007) - S01E07 - The Dumpling Paradox.ts
The Big Bang Theory (2007) - S01E08 - The Grasshopper Experiment.ts
The Big Bang Theory (2007) - S01E09 - The Cooper-Hofstadter Polarization.ts
The Big Bang Theory (2007) - S01E10 - The Loobenfeld Decay.ts
The Big Bang Theory (2007) - S01E11 - The Pancake Batter Anomaly.ts
The Big Bang Theory (2007) - S01E13 - The Bat Jar Conjecture.ts
The Big Bang Theory (2007) - S01E14 - The Nerdvana Annihilation.ts
The Big Bang Theory (2007) - S01E15 - The Pork Chop Indeterminancy.ts
The Big Bang Theory (2007) - S01E16 - The Peanut Reaction.ts
The Big Bang Theory (2007) - S01E17 - The Tangerine Factor.ts
/media/video/tv/The Big Bang Theory (2007)/Season 02:
The Big Bang Theory (2007) - S02E01 - The Bad Fish Paradigm.ts
The Big Bang Theory (2007) - S02E02 - The Codpiece Topology.ts
The Big Bang Theory (2007) - S02E03 - The Barbarian Sublimation.ts
The Big Bang Theory (2007) - S02E04 - The Griffin Equivalency.ts
The Big Bang Theory (2007) - S02E05 - The Euclid Alternative.ts
The Big Bang Theory (2007) - S02E06 - The Cooper-Nowitzki Theorem.ts
The Big Bang Theory (2007) - S02E07 - The Panty Pinata Polarization.ts
The Big Bang Theory (2007) - S02E08 - The Lizard-Spock Expansion.ts
The Big Bang Theory (2007) - S02E09 - The White Asparagus Triangulation.ts
The Big Bang Theory (2007) - S02E10 - The Vartabedian Conundrum.ts
But when I view them in the player it does not separate them by Season.
How do I fix this.
TV shows that I have ripped from my DVDs show up just fine.
Thanks,
Edit the show (pencil icon in the bottom-left corner of its poster) and view its advanced settings. Make sure Seasons is set to Show:
Your suggestion resolved my issue. Such and easy fix. Can’t believe I never found that.setting.
Is there a way to make that the default setting?
Thanks for your help.
There’s a library-level setting of the same name, in the advanced section:
If you select “Library default” for the show-level setting, it should inherit this value. However, I’ve noticed that with some DVR content that doesn’t always work as expected and I have to manually configure it for the show.
Thanks. I already had that set in my settings.
