Server Version#: 4.145.1
Hello everyone,
I run Plex server on a virtual DSM on a Synology NAS DS918+. The virtual DSM is hidden behind a NordVPN VPN, not the host which is accessible from outside.
Everything runs great on LAN except that, of course, I don’t have remote access to PLEX as DSM has a NordVPN connection activated 24/7.
To be precise, DSM host has an aggregation of the 2 links (Link 1 + Link 2 = Bond).
The only thing I would see would be to remove the bond and assign link 1 to one kind of traffic and link 2 to VPN but I’m really not sure about this.
Router is a pfSense 2.7.2 where NAT has been created translating ports to PLEX (32400).
I was wondering if someone has the same kind of setup and made it work.
If someone has the solution, I’ll take it !
I use NAT port forwarding rules to forward the WAN port to internal 32400.
I would not break the DSM network adapter bond.
PMS works best when there is only one network adapter.
It is often confused when multiple adapters are involved.
( I have two adapters on my PMS machine which are aggregated. It works without issue in this configuration )
There is no VPN in my configuration. PMS uses HTTPS. All traffic is encrypted in that HTTPS connection.
I created in pfSense an OpenVPN account accessing the LAN and somehow I can access PMS with it but only with a navigator https://app.plex…
The app doesn’t connect for some reason.
It will find the libraries and display them but when I click on something to play I get a “something went wrong - close / retry” window. I am going to check the logs to see where it bugs.
