Not using french season posters
The season poster for the TV Show below dont show up in Plex with the new scanner (French TV shows).
The rest of metadata looks OK, poster for the show themselves are fine, library configured in french.
Hope you can help, let me know if you need more details.
@JDA88 If you edit one of the shows itself does it show as french or library default for that show?
So, library is set to French:
And on the TV Show, everything is set to “Library Default” (on all the show I listed)
When I edit Season 2 i have no poster availeable:
But on TheTVDB.com they exist:
Irresponsable - Aired Order - Season 2
Oh I see, in my screen shot it is using the show poster again, not the season poster.
Thanks for report @JDA88 this does seem like a general issue since it happened to multiple shows and I can reproduce so I making a bug report for it.
Great, if you want any more information or test let me know
Since then I found a lot more that have similar issues (all are no-US show, mostly french).
Want to me to wait for a fix before listing new ones or do i add the others to the list?
whenever we can fix it, it should cover all of them.
