I recently decided to finally upgrade my Plex Library to the new library/database so I can get rid of the annoying notification about it. However it seems like Season posters are not showing up or being pulled. I don’t know if I need to manually always add the Season poster now?
Server Version#:1.28.1.6104
Did you Refresh Metadata for the whole library, after triggering the conversion?
And if so, did you wait for its completion?
Not sure if this is happening on all your shows, or just the one in the screenshot. If it’s just “Surface,” thetvdb.com doesn’t appear to have a season-specific poster.
When there’s no season poster it should use the show poster. You don’t have to select it manually if it’s working properly
