I’ve downloaded plex media server and when I opened it to plex and go to add media it still says “Add your media to Plex, Get Plex Media Server”
what should I do?
what should I do?
Make sure to complete the setup by opening your newly installed Plex Media Server through its local IP address.
This will walk you through the setup where you can name your server, link it to your Plex account and create your first libraries (which you can also create/change later). Once your server is setup and linked to your Plex account you’ll also be able to access it from other Plex apps (e.g. using the hosted version of Plex Web → https://app.plex.tv/desktop).
Didn’t work
Thanks for sharing.
Are there’s anything else I can do?
You might want to start with sharing some more details.
“it’s not working” is very thin for a halfway decent troubleshooting.
Are you on the same machine / inside the same network when trying to access your server?
Did you already have another instance of Plex Media Server installed at some earlier point of time – maybe one already connected with a different Plex account?
When you open the given URL… are you still getting the exact same message or are you getting a few steps further?
So I downloaded it and when I finished everything else, I booted up my plex and I takes to the the normal home menu and I clicked on the + sign (aka add media) it still says “Add your media to Plex, Get Plex Media Server” despite me already having the server
And you’re getting that while accessing the server through the bundled version of Plex Web (http://127.0.0.1:32400/web while being on the same Mac)?
Yes and I use Windows
In case you previously had a Plex Media Server installed on that machine… try this procedure to erase some potential leftovers which could cause the server to think you’re not authorized to see the actual server.
I’ve tried that and everything else to no sucess.
Thanks for trying to help anyway.
Guess, I’ll never use my media server -_-
