Server Version#: 1.24.5.5173
Player Version#: 7.0-41890
I’ve tried everything, pretty frustrated to be honest. Even killed the original folders out of diskstation and created new folders and still doesnt work. Here is one example of how a photo library that has photos from one of my son’s tablets is currently set up:
I can see the jpgs in both diskstation/filestation and directly in windows as a mapped drive no problem. I uninstalled PMS from package center, then deleted the root plex and plexmediaserver directories out of filestation/control panel. Then I made sure there were no plex or plexmediaserver users in any of the permissions folders, then I created new media folders in control panel and reinstalled the latest version of pms for DSM 7 64bit on my DS1019. Added libraries in plex and still can’t see any media.
Thanks for the reply. I thought that might be the case so I created a fresh folder to put the photos in when I wiped everything and restarted. Still no luck.
Sorry for the delay, nuked again and tried to start over with just one library that is my movies which is located here “/volume1/media/Movies”. Same results where it says ““Movies” is empty
Expecting more? Visit the Manage Libraries page to add folders and scan library files.”. PlexMediaServer still has Read/Write on the permissions tab in Control Panel/Shared Folder/media
Oct 29, 2021 10:37:39.572 [0x7f44edc19b38] DEBUG - Performing a scan with 'Plex Movie' (language: en-US virtual: 0).
Oct 29, 2021 10:37:39.572 [0x7f44edc19b38] DEBUG - * Scanning /volume1/media/Movies
Oct 29, 2021 10:37:39.572 [0x7f44edc19b38] ERROR - Failed to create iterator to "/volume1/media/Movies": Permission denied
Oct 29, 2021 10:37:39.572 [0x7f44edc19b38] DEBUG - * Marking media not available in /volume1/media/Movies
Oct 29, 2021 10:37:39.572 [0x7f44edc19b38] DEBUG - * Taking 0 items out of the map (which has 0 items) for
The permissions did not extend / were dropped in the sub folders.
Using File Station,
Right-Click → Properties → Permission
Grant permission for PlexMediaServer and make certain to Apply to this folder, sub-folders and files
I’m sure I’ve granted permission.All existing resources could be read, even transferred to other folders in time.But the new resources can not be read.
Oct 29, 2021 23:37:46.077 [0x7f16f5c4ab38] DEBUG - Loading information from media bundle for part ID 833 from "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Media/localhost/f/8e05c208232b70b6362da40f44e13f1190fd686.bundle/Contents"
Oct 29, 2021 23:37:46.078 [0x7f16f5c4ab38] DEBUG - There was a change for metadata item 900 (吉翁之子), saving.
Oct 29, 2021 23:37:46.078 [0x7f16f5c4ab38] DEBUG - Updating metadata item (save) (吉翁之子) with ID 900
Oct 29, 2021 23:37:46.090 [0x7f16f5c4ab38] DEBUG - * Season 1 (-1) Episode 5 (-1) (1900-01-01)
Oct 29, 2021 23:37:46.090 [0x7f16f5c4ab38] DEBUG - Looking up season and index for an episode, indexKey=S01E05 dateKey=.
Oct 29, 2021 23:37:46.090 [0x7f16f5c4ab38] DEBUG - * Found episode with key S01E05
Oct 29, 2021 23:37:46.090 [0x7f16f5c4ab38] DEBUG - * Found episode s01e05
Oct 29, 2021 23:37:46.090 [0x7f16f5c4ab38] DEBUG - Migrating metadata settings from local://899 -> com.plexapp.agents.themoviedb://88865/1/5?lang=zh
Oct 29, 2021 23:37:46.095 [0x7f16f5c4ab38] DEBUG - Item 899 (夏亚和卡尔玛) Scanning metadata graphic elements in XML file "seasons/1/episodes"/5.xml
Oct 29, 2021 23:37:46.096 [0x7f16f5c4ab38] DEBUG - Item 899 (夏亚和卡尔玛) Scanning metadata graphic elements in XML file "seasons/1/episodes"/5.xml
Oct 29, 2021 23:37:46.098 [0x7f16f6a9ab38] DEBUG - HTTP requesting GET http://127.0.0.1:37418/system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F88865%2F1%2F5%3Flang%3Dzh&mediaType=4&url=metadata%3A%2F%2Fseasons%2F1%2Fepisodes%2F5%2Fthumbs%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_fce888ed01e04bc4bf3e72ddb1534db622d78e81
Oct 29, 2021 23:37:46.861 [0x7f16f6a9ab38] DEBUG - HTTP/1.1 (0.8s) 200 response from GET http://127.0.0.1:37418/system/agents/media/get?guid=com%2Eplexapp%2Eagents%2Ethemoviedb%3A%2F%2F88865%2F1%2F5%3Flang%3Dzh&mediaType=4&url=metadata%3A%2F%2Fseasons%2F1%2Fepisodes%2F5%2Fthumbs%2Fcom%2Eplexapp%2Eagents%2Ethemoviedb_fce888ed01e04bc4bf3e72ddb1534db622d78e81 (reused)
Oct 29, 2021 23:37:46.861 [0x7f16f5c4ab38] DEBUG - Brought media local (metadata://seasons/1/episodes/5/thumbs/com.plexapp.agents.themoviedb_fce888ed01e04bc4bf3e72ddb1534db622d78e81) in 763ms.
Oct 29, 2021 23:37:46.861 [0x7f16f5c4ab38] DEBUG - Loading information from media bundle for part ID 832 from "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Media/localhost/9/6d9377ceff720f1ebfc190620b405d41d105388.bundle/Contents"
Oct 29, 2021 23:37:46.862 [0x7f16f5c4ab38] DEBUG - There was a change for metadata item 899 (夏亚和卡尔玛), saving.
Oct 29, 2021 23:37:46.862 [0x7f16f5c4ab38] DEBUG - Updating metadata item (save) (夏亚和卡尔玛) with ID 899
Oct 29, 2021 23:37:46.874 [0x7f16f5c4ab38] DEBUG - * Season 1 (-1) Episode 43 (-1) (1900-01-01)
Oct 29, 2021 23:37:46.874 [0x7f16f5c4ab38] DEBUG - Looking up season and index for an episode, indexKey=S01E43 dateKey=.
Oct 29, 2021 23:37:46.874 [0x7f16f5c4ab38] DEBUG - * Found episode with key S01E43
Oct 29, 2021 23:37:46.874 [0x7f16f5c4ab38] DEBUG - * Found episode s01e43
Oct 29, 2021 23:37:46.874 [0x7f16f5c4ab38] DEBUG - Migrating metadata settings from local://901 -> com.plexapp.agents.themoviedb://88865/1/43?lang=zh
Oct 29, 2021 23:37:46.879 [0x7f16f5c4ab38] DEBUG - Item 901 (Episode 43) Scanning metadata graphic elements in XML file "seasons/1/episodes"/43.xml
Oct 29, 2021 23:37:46.881 [0x7f16f5c4ab38] DEBUG - Item 901 (Episode 43) Scanning metadata graphic elements in XML file "seasons/1/episodes"/43.xml
Oct 29, 2021 23:37:46.882 [0x7f16f5c4ab38] DEBUG - Loading information from media bundle for part ID 834 from "/var/packages/PlexMediaServer/shares/PlexMed
I think you just need to wait until all the work it’s doing is completed.
Although that didn’t resolve my issue, it lead me to this which fixed it
None of these check boxes were toggled on. Also in the General tab the Owner was not set to “admin” and the Group was set to “users”. I set both of these tabs as shown and now I’m in business!
Thanks again Chuck
