Nvidia Hardware Transcoding Not Working
Hi All,
First post here and I’m new to Plex so please go easy on me.
I have a HP Microserver Gen8, Specs Below:
Intel Xeon E3-1220L
16GB RAM
Nvidia GeForce GT 1030
250GB SSD for Windows Server 2016 Standard and Plex Media Server
4x 4TB WD Red’s in RAID 10 (8TB Usable Space).
Plex and all it’s metadata is stored on the SSD (NTFS).
All Library data is stored on the WD Red’s (ReFS).
Most of my library are Blu-ray rips from my Blu-ray collection, Transcoded in HandBrake usually taking up 8GB-15GB and nothing really exceeding 10Mbps Original Quality.
Playback is smooth but the little Xeon is usually around 90-100% usage on one stream.
So I was hoping if I enabled Hardware Acceleration it would use the 1030 and thus allow more than one stream at a time.
Problem is, it never seems to touch the GPU, Xeon is still maxing out and I can see no GPU usage at all.
Is there a way to force Plex to see the GPU? I completely wiped and re-built my server last night (latest firmware’s and Drivers across the board) And I’ve got Plex Pass so made sure I have the latest build of Plex installed as well.
Thanks in advanced.
Are you running Plex as a system service?
If so, only _en_coding on the GPU is available.
Is a monitor connected to the graphics adapter?
If not, GPU acceleration won’t work. If you don’t have a monitor, you can use a simulator plug.
In general, this particular Xeon is a very weak affair. And it doesn’t have a GPU integrated, like all Xeons. You’d be better off with a middle-class Core i5.
Ah ok, thanks. Yes it is running as a service.
No monitor is plugged into the GPU, I’m using the built-in Matrox Adapter as the primary GPU so I can keep iLO working etc…
Can I still use the Nvidia GPU then if it’s the secondary adapter? It’s installed and detected fine.
I do plan to upgrade to the Xeon E3-1265L v2 but I haven’t had the funds at the moment and to be honest, the little Duel Core plays one transcoded stream fine along with a direct stream.
The reason for this CPU is because the server is on 24/7 and the little power it takes is quite attractive.
Then you’ll can’t have hardware assisted decoding.
This scenario is not well tested and there may be yet unknown issues around it. Connect a monitor or an emulator plug to the nVidia adapter and try again.
That’s a shame, Considering they call it Plex Media SERVER and it runs in the background anyway, I thought running it as a Service wouldn’t cause any of it’s functionality to stop working. The Server is not on a domain and the Service is running as the local Administrator account to make sure permissions are not an issue.
Thanks, I will be giving this a go tonight, What i’ll do is change it so that the Nvidia Card is the only one enabled in the BIOS (So i’ll lose iLO functionality but I can live with that since i’ll have RDP Access) and use the Emulator Plug and see how I get on.
UPDATE:
Success! I’ve got Hardware Acceleration working, I need to test with the HP Matrox GPU also enabled but currently I’m getting the below results:
30~% CPU utilization and extremely little GPU utilization (2-24% depending on buffering)
Compared to:
100% CPU utilization and no GPU utilization
Tested using a raw Guardians of the Galaxy Vol.2 1080p Blu-ray rip and on multiple devices (Chrome Browser, Apple TV, Windows App and Android 8.0 (Sony Xperia XZ Premium)). It almost always transcodes the Audio which is expected.
It appears to be completely down to Plex running as a Service, it simply doesn’t Hardware Accelerate as a Service. Real shame, that would make it a proper “Server” so to speak but I can live with just disconnecting my RDP session.
I now have a very low power Plex Server that’s capable of (I think) 4K HDR movie playback (when they crack AACS 2.0 and I can start buying and ripping 4K Blu-ray’s). Even if not, I can now at least handle 2 Streams rather than one!
Note: I did not have to add any fake screens attached or anything, works without any screen being connected.
LAST UPDATE:
Success again! Even with the Matrox GPU enabled, It detects the Nvidia card and hardware accelerates fine. Even raw HEVC Blu-Ray Rips.
Bad news, The little Xeon Duel Core cannot transcode Dolby Atmos properly and so the video buffers every 10 seconds.
Looks like i’ll be upgrading to the Xeon E3-1265L v2 anyway!
@Burty101s said:
LAST UPDATE:
Please post an update after you upgrade your CPU. I’m wanting to build a similar setup to what you have going here and am curious if the updated CPU will solve the Atmos problem.
Thanks in advance!
Have two gpu’s in my system. An AMD RX480 hooked up to my monitor and a QUADRO P2000 as a encoder/decoder card. This works just fine for EMBY. It even lets me choose which GPU I want to use as hardware transcoding, although it recognized the QUADRO automatically as the dedicated transcode card. Why doesn’t Plex let us choose the GPU to use as hardware transcoding or recgonize that I do have a capable GPU in my system? I don’t want my P2000 hooked up to my monitor because I don’t want to waste a couple percent running the display on the QUADRO card and other miscellaneous GPU processes and programs I have running on the computer.
how do you do that?
I choose “Enbedded Video Primary, Optional Video Secondary”, but didn’t get HW working.
please help adive.
Apologies, I hadn’t had any notifications of you guys replying!
Yes the CPU upgrade completely fixed the Dolby Atmos issues, I now have a relatively low power Microserver that can serve raw 4K movies including Dolby Atmos sound without a hiccup.
Hi zengkid, Plex cannot run as a service, this disables it’s ability to Hardware Accelerate.
What i’ve done is setup my server to auto login to a plex account and start plex straight away. So I always have a user logged in with plex running, that seems to have done the trick.
What GPU are you using? This can also have an effect on what Plex can and cannot transcode on it.
This is a question for Plex themselves, I agree with making this feature far more apparent, it would be nice if once you tick “Use Hardware Acceleration” it then gave you the details of the hardware it’s using and even pick the hardware you want to use. All developer time though and I’m not sure what they spend their time on at the moment, I know they recently brought live TV to Plex so I assume they’re ironing those features out at the moment.
Hi, Burty, My Plex Server start as the account login, not run as service.
the GPU is GT 1030.
what’s your video options setup in BIOS?
Are you logging in with an account that can run with administrative privileges? Mine is the same as yours:
“Embedded Video Primary, Optional Video Secondary”
Mines Server 2016 Standard running straight on the server, no Virtualization.
gt1030 only can decode, but can’t encode. and then CPU will help to encode to stream . so 1030 is not good for plex.
Seems fine to me but I don’t do any encoding on the server, I encode my videos on my desktop PC then move them onto the server for Plex to dish out so the 1030 is only being used to decode which it does very well (tested on a raw rip of a 4k blu-ray and it had no trouble).
Transcoding will be where you lose HW accel as it needs to re-encode to something the client can handle.
@Burty101s
I’m struggling to get this working.
I have an identical set up to you - Gen8, E3-1265LV2, GT 1030.
Embedded set as primary, GT 1030 set as secondary in BIOS.
I have HW encoding ticked in PMS, not running it as a service, latest Nvidia driver installed.
All transcoding is still done by the CPU. What could I have missed?
Maybe I need to configure the GT 1030 as primary display within Windows 10?
I think to do that I am gonna have to hook up a monitor, KB/Mouse as there doesn’t appear to be any way to do it from RDP or iLO console.
