Nvidia shield help
I have a problem…I woke up this morning went to my nvidia shield which has no hardRIVE anyway I launched plex and the plex home screen says no item to display this directory appears to be empty
The plex web on my computers browser appears fine it shows everything same on cell phone it appears fine
its just the shield home screen now if i go to more and manually select tHe server it shows everything i have pinned and i select everything from there
But the Plex Home screen in the shield still says no item to display this directory appears to be empty
Did someone release a bad update anyone know a fix please help
This happened with my Shield as well.
Re-pin the desired libraries.
A recent update caused libraries to become unpinned.
Thank you sir!
Will this reoccur or is it a one time thing?
I doubt it was a planned event.
I’ve had a Shield for several years. Never happened before.
Please follow the thread below for updates (scroll to bottom, change Normal to Watching). There are several threads on the topic in the forum. Trying to consolidate into one thread, so it will be easier to track the issue.
