Server Version#: 1.25.2.5319 (Unraid docker)
Player Version#: 8.27.2.29938 (Nvidia Shield Pro)
Hi All, I’m hoping either someone can help or there are others that have this issue also;
Occassionally when I play a video on my Nvidia Shield Pro, it will trigger the loading icon and just sit there, and do nothing - I can leave it there for 5 minutes and nothing will happen.
If I hit back and play the video again, sometimes it’ll work, sometimes it’ll do the same thing. Most of the time navigating up one level on a TV show or to a different hub (movie to tv, tv to movie) and back to play the same item, it will play as normal.
I have turned on network logging on the Player - please see attached.
I have also attached server logs for the same time - please see attached.
A confirmed time of the event in the logs is at 12-24 18:09 (right down the bottom on both log files)
I can see in the server logs the message -
Failed to stream media, client probably disconnected after 124780544 bytes: 104 - Connection reset by peer
I can confirm I did not stop playing the video at this time (in fact went to my computer to save the logs)
There appears to be a repeating pattern within the client logs, unsure if this means anything?
It goes on until I have to stop the infinite loading icon (Ubereats had arrived!)
12-24 16:18:28.034 i: [PlaybackTimeBehaviour] Time: 966489 IsStarted: true
12-24 16:18:28.169 i: [ExoPlayer][EventLogger] loading [eventTime=981.90, mediaPos=6002.52, window=0, period=0, true]
12-24 16:18:28.169 i: [ExoPlayer][EventLogger] loading [eventTime=981.90, mediaPos=6002.52, window=0, period=0, false]
12-24 16:18:28.343 i: [ExoPlayer][EventLogger] loading [eventTime=982.08, mediaPos=6002.69, window=0, period=0, true]
12-24 16:18:28.343 i: [ExoPlayer][EventLogger] loading [eventTime=982.08, mediaPos=6002.69, window=0, period=0, false]
12-24 16:18:28.679 i: [ExoPlayer][EventLogger] loading [eventTime=982.41, mediaPos=6003.02, window=0, period=0, true]
12-24 16:18:28.683 i: [ExoPlayer][EventLogger] loading [eventTime=982.41, mediaPos=6003.02, window=0, period=0, false]
Any help to fix this issue would be appreciated
plex.logging.txt (4.5 MB)
server.Plex Media Server.3.log (10.0 MB)
