Nvidia Shield - Sync stops halfway with error
Hey all,
Whenever i try to sync a movie/episode to any of my devices, i keep getting an error on the device saying there is an error with this file. Below is a relevant log when this happens. I cannot seem to find a solution to the problem i am having on the forum. Note: this problem happens with all my media files, and i tried to sync to 3 different devices.
Having bought pex pass mainly for this feature and runnning into this issue is quite annoying!
Hope to find a solution!
Jul 14, 2018 08:02:00.262 [4396] DEBUG - Jobs: '/data/user/0/com.plexapp.mediaserver.smb/Resources/Plex Transcoder' exit code for process 24315 is -9 (signal: Killed)
Jul 14, 2018 08:02:00.263 [24291] DEBUG - Transcoder: Cleaning old transcode directories.
Jul 14, 2018 08:02:00.299 [24269] DEBUG - Streaming Resource: Changing client to use software decoding
Jul 14, 2018 08:02:00.317 [24269] ERROR - Streaming Resource: Cannot redecide static session
Jul 14, 2018 08:02:00.317 [24269] DEBUG - Streaming Resource: Terminating session 0x293a121860:e412d377-a9ed-41ff-b66a-edf16134f553 which is using static transcoder slot.  Used slots is now 0
Jul 14, 2018 08:02:00.317 [24269] DEBUG - Streaming Resource: Terminated session 0x293a121860:e412d377-a9ed-41ff-b66a-edf16134f553 with reason Neither direct play nor conversion is available.
Jul 14, 2018 08:02:00.317 [24287] DEBUG - Killing job.
Jul 14, 2018 08:02:00.317 [24287] DEBUG - Signalling job ID 24315 with 9
Jul 14, 2018 08:02:00.317 [24287] DEBUG - Job was already killed, not killing again.
Jul 14, 2018 08:02:00.317 [24287] DEBUG - Stopping transcode session e412d377-a9ed-41ff-b66a-edf16134f553
Jul 14, 2018 08:02:00.352 [4383] DEBUG - Auth: authenticated user 1 as smashernl
Jul 14, 2018 08:02:00.353 [22851] DEBUG - Request: [62.72.193.84:22993 (WAN)] GET /status/sessions/background (10 live) TLS GZIP Signed-in Token (smashernl)
Jul 14, 2018 08:02:00.356 [24287] DEBUG - Transcoder: Cleaning old transcode directories.
Jul 14, 2018 08:02:00.356 [4383] DEBUG - Completed: [62.72.193.84:22993] 200 GET /status/sessions/background (10 live) TLS GZIP 3ms 752 bytes (pipelined: 115)
Jul 14, 2018 08:02:00.356 [24291] DEBUG - Transcoder: Cleaning old transcode directory: /storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache/Transcode/Sessions/plex-transcode-e412d377-a9ed-41ff-b66a-edf16134f553-dc633682-7fb0-4eb7-9114-0b23f7ff6685
Jul 14, 2018 08:02:00.358 [24291] DEBUG - Whacked session e412d377-a9ed-41ff-b66a-edf16134f553, 0 remaining.
Jul 14, 2018 08:02:00.358 [24291] DEBUG - TranscodeJobManager: transcode of metadata item 34 failed with exit code -9
Jul 14, 2018 08:02:00.427 [24287] DEBUG - Whacked session e412d377-a9ed-41ff-b66a-edf16134f553, 0 remaining.
Jul 14, 2018 08:02:00.433 [24291] DEBUG - TranscodeJobManager: [Running] job e412d377-a9ed-41ff-b66a-edf16134f553 complete - failure / transcoderError
Jul 14, 2018 08:02:00.433 [24993] DEBUG - BPQ: onAsynchronousJobComplete
Jul 14, 2018 08:02:00.434 [24993] DEBUG - BPQ: completing transcode for sync metadata item 34: failure / transcoderError
Jul 14, 2018 08:02:00.448 [24993] DEBUG - Sync: processed item 34 for sync list 26486280, sync item 28685885: failure/transcoderError
Jul 14, 2018 08:02:00.448 [24993] DEBUG - BPQ: generator 33 changed state: pending -> complete
Jul 14, 2018 08:02:00.449 [24993] DEBUG - Sync: sync list 26486280, sync item 28685885 changed state from pending to complete
Jul 14, 2018 08:02:00.449 [24993] DEBUG - Sync: sync list 26486280, sync item 28685885: complete/good with 1/0/1/0/0/0 item(s)
Jul 14, 2018 08:02:00.449 [24381] DEBUG - HTTP requesting PUT https://plex.tv/devices/fbae9c444d9af594-com-plexapp-android/sync_items/28685885/status?auth_token=xxxxxxxxxxxxxxxxxxxx&itemsCompleteCount=1&itemsCount=1&itemsDownloadedCount=0&itemsReadyCount=0&itemsSuccessfulCount=0&state=complete&totalSize=0
Jul 14, 2018 08:02:00.450 [24994] DEBUG - HTTP requesting POST https://plex.tv/devices/fbae9c444d9af594-com-plexapp-android/notifications?Notification[collapseKey]=syncItemCompleted&Notification[data]=action%3DsyncItemCompleted%26syncItemID%3D28685885%26syncListID%3D26486280&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Is someone able to look into this? I have tried every possible suggestion i could find on the forum, but no avail. It seems that transcoding just stops after 15 minutes but i have no idea why.
What on earth does one have to do to get some support in here? I have this problem since the very latest server update, and found out that the server also instantly crashes when playing a video with subtitles and when you are lucky enough that does not happen, the playback is not smooth at all with constant frame skipping.
Tested a previous version of the Plex Server and all works well, so seems to be an issue with the latest release. @anon18523487, can someone of the team have a look?
Hey smashernl, I’ve exactly the same problem as yours.
For about two months more or less, I can’t sync anything to my different devices (two iPad) from my Nvidia Shield server.
But It seems to be working when I deactivate the hardware acceleration on the transcoder (server settings).
Try this, maybe it will solve your problem.
I hope Plex Team will fix this quickly because, it’s quite annoying to have to deactivate the reason why you’ve bought a Nvidia Shield in the first place…
Hey there and thanks for your helpful contribution. I can confirm that turning off hw acceleration resolves the problem, but indeed the Shield is nothing without hw acceleration. I agree that this is not a satisfactory solution and hope the Plex team will at least confirm the existance of this problem.
Oh my god, with this server even local playback seems to be failing, in combination with the Plex client on the shield. With some media files, the app instantly crashes and i cannot get it to play normally. Thanks very much plex staff for the updates regarding these issues, and releasing a version that is not even ready to leave the Alpha stage.
This issue is still happening with the latest server update
Jul 27, 2018 08:19:40.670 [5663] DEBUG - Jobs: '/data/user/0/com.plexapp.mediaserver.smb/Resources/Plex Transcoder' exit code for process 9240 is -9 (signal: Killed)
Jul 27, 2018 08:19:40.687 [5654] DEBUG - Auth: authenticated user 1 as smashernl
Jul 27, 2018 08:19:40.688 [9477] DEBUG - Request: [192.168.1.3:49383 (Subnet)] GET /status/sessions/background (13 live) TLS GZIP Signed-in Token (smashernl)
Jul 27, 2018 08:19:40.690 [5654] DEBUG - Completed: [192.168.1.3:49383] 200 GET /status/sessions/background (12 live) TLS GZIP 2ms 749 bytes (pipelined: 1)
Jul 27, 2018 08:19:40.734 [9441] DEBUG - Streaming Resource: Changing client to use software decoding
Jul 27, 2018 08:19:40.734 [9441] ERROR - Streaming Resource: Cannot redecide static session
Jul 27, 2018 08:19:40.734 [9441] DEBUG - Streaming Resource: Terminating session 0x22fb83c7e0:60af57dc-3eda-478a-b461-a9a0a6182877 which is using static transcoder slot.  Used slots is now 0
Jul 27, 2018 08:19:40.734 [7681] DEBUG - Transcoder: Cleaning old transcode directories.
Jul 27, 2018 08:19:40.791 [9441] DEBUG - Streaming Resource: Terminated session 0x22fb83c7e0:60af57dc-3eda-478a-b461-a9a0a6182877 with reason Neither direct play nor conversion is available.
Jul 27, 2018 08:19:40.823 [7681] DEBUG - Transcoder: Cleaning old transcode directory: /storage/emulated/0/Android/data/com.plexapp.mediaserver.smb/cache/Transcode/Sessions/plex-transcode-60af57dc-3eda-478a-b461-a9a0a6182877-38640e99-b554-4089-bed3-73f3a55fca1b
Jul 27, 2018 08:19:40.826 [7681] DEBUG - Whacked session 60af57dc-3eda-478a-b461-a9a0a6182877, 0 remaining.
Jul 27, 2018 08:19:40.826 [7681] DEBUG - TranscodeJobManager: transcode of metadata item 44 failed with exit code -9
Jul 27, 2018 08:19:40.887 [7681] DEBUG - TranscodeJobManager: [Running] job 60af57dc-3eda-478a-b461-a9a0a6182877 complete - failure / transcoderError
Jul 27, 2018 08:19:40.887 [10270] DEBUG - BPQ: onAsynchronousJobComplete
Jul 27, 2018 08:19:40.887 [10270] DEBUG - BPQ: completing transcode for sync metadata item 44: failure / transcoderError
Jul 27, 2018 08:19:41.076 [10270] WARN - Held transaction for too long (../Sync/SyncItemProcessor.cpp:295): 0.180000 seconds
Jul 27, 2018 08:19:41.182 [10270] DEBUG - Sync: processed item 44 for sync list 26676264, sync item 29030797: failure/transcoderError
Jul 27, 2018 08:19:41.182 [10270] DEBUG - Sync: sync list 26676264, sync item 29030797: pending/good with 2/0/5/0/0/0 item(s)
Jul 27, 2018 08:19:41.182 [9177] DEBUG - Killing job.
Jul 27, 2018 08:19:41.182 [9177] DEBUG - Signalling job ID 9240 with 9
Jul 27, 2018 08:19:41.182 [9177] DEBUG - Job was already killed, not killing again.
Jul 27, 2018 08:19:41.182 [9177] DEBUG - Stopping transcode session 60af57dc-3eda-478a-b461-a9a0a6182877
Jul 27, 2018 08:19:41.183 [10270] WARN - [Analytics] Attempting to send unrecognized metric (sync:processed). Skipping.
Jul 27, 2018 08:19:41.233 [9177] DEBUG - Transcoder: Cleaning old transcode directories.
Jul 27, 2018 08:19:41.237 [9177] DEBUG - Whacked session 60af57dc-3eda-478a-b461-a9a0a6182877, 0 remaining.
Jul 27, 2018 08:19:41.244 [7189] DEBUG - HTTP requesting PUT https://plex.tv/devices/b0e47e03ce406bc3-com-plexapp-android/sync_items/29030797/status?auth_token=xxxxxxxxxxxxxxxxxxxx&itemsCompleteCount=2&itemsCount=5&itemsDownloadedCount=0&itemsReadyCount=0&itemsSuccessfulCount=0&state=pending&totalSize=0
Jul 27, 2018 08:19:41.352 [10270] DEBUG - BPQ: [Idle] -> [Processing]
Jul 27, 2018 08:19:41.354 [10270] DEBUG - PlayQueue: total generated: -1, before cursor: 0, after cursor: 2
I would be really grateful is someone can have a look at this.
This is the same topic
And this one: SHIELD hardware transcoding problem?
