I switched my server to Home. At my Xbox, I used a free account to share with and sign into so that I did not see all my libraries (just movies and TV shows).
Now sometimes, I get into the main menu the. When I select a library, I get a server error. The server version is current, but I’ll double check the version.
Well I restart the server and that doesn’t help most of the time. A reboot of the Xbox seems to be the more consistent fix. But the weird thins is I am in “energy saving” mode so last time it occurred, it was off a fresh boot.
Mods, if this should be in the Home section, please move, but this felt more appropriate given the typical resolution.
Just tried again and it seemed fine. So it is definitely intermittent.
Philip
Currently the Xbox One only shows Movies and TV Folders, Channels and Music are not loaded.
There is currently a problem when going into TV Show libraries. The Dev's are working on a fix. On my Xbox One when this happens if I just hit retry the folder loads but only the browse option is there which leads to the individual show folders.
---edit
Just wanted to leave an update for you, this should be fixed in 9.11.16 which was released a little earlier. (At least it appears to be working on my Xbox One with my FreeBSD server)
Cool. I’ll get it loadd up. I am aware of the library type restriction. I have tv shows and kids tv shows for instance. But yea you are correct, iris only on tv shows. I will post results.
