Old Versions Of Plex For Mac
Hey, just KILLED my mac with the new Plex server!!! Where do I find older versions for mac?
Thanks,
Kevin
how did you kill your mac?
there’s a number of use cases where downgrading your PMS won’t fix whatever issue you’re experiencing…
probably means he b0rked an old MacOS < 11.0.0 with PMS > 1.29.0.6244.
If you’re running let’s say 10.14.6 like I am, I wrote up a how to downgrade with links to a couple of older versions that work.
If you’re after something else, try up around post 36 for really old versions.
