Server Version#: Version 1.21.0.3616
Player Version#: Version 4.43.4
On the bottom of my LG TV the menu will not go away while watching my videos. I constantly have to see on the top (title) and bottom (navigation options) throughout the whole show/movie. This just started yesterday after using the program for years.
I have powered up the LG, it just seems strange that it just started happening yesterday after years with the same TV. I checked my newer LG and it works fine, just the older one that is acting up.
Oh, that a early LG smart. I had one of those back a few years ago.
You definitely need to opt out. Go to app avatar top left and opt out.
If you have a lot of apps installed it’s best to thin them out and remove the stored recent in bottom tiles left. Those early models struggled with available RAM and processors were barely appropriate.
I appreciate the advice. I don’t have or use any other apps on the TV, I checked to see if I installed any others, and I haven’t. It would be a shame/pain if I can’t find a resolution, it’s my largest TV…
Well it’s an older TV but a second hand Roku would solve the problem and vastly improve the use of PLEX. Amazon or Ebay, don’t recommend the Roku stick.
Update: there are plenty Roku 4K units for $20 on ebay, this will give you many more years on the older LG
