One episode is not discovered by plex
I have 2 episode of a serie, and when i copy them in my TV Show folder, only one is shown in plex.
If I copy the one episode that I can’t see in TV Shows, in a Movies folder, I can see it!?
Why? Any help to fix this issues?
Are you following the Plex naming guide for tv shows exactly?
(Please don’t say you are naming all your files the same way. It is important to name them the right way.)
Please give an example with actual file and folder names.
Thanks for the tip.
I will look in to this, and sort it out :slight_smile:
