Server Version#: Newest version
Player Version#: I use the website
Hello, I set up everything with my freenas server, I have about 40 movies but only 25 show up on plex. All movies are named with the name of the movie and then the date (All the movies are in 1 folder). Does somebody know why the rest isn’t showing up?
You can check inside Plex for movies that Plex perceived as duplicates (open the library, click on Filter and select Duplicates – or check for items with a blue-ish box on their cover with a number, indicating there’s different versions of that movie).
If the media is actually missing… there’s always the question of permissions with Linux/Unix based content. Have you checked if Plex can see those missing movies?
