OPENDNS "block internal IP addresses" feature makes Plex go indirect
EDIT: Read my next post for the solution.
192-168-200-2.xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.plex.direct
How often does that xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx change?
I was able to cobble together a quick solution for an indirect connection on my local network, by putting a host override in unbound on pfSense.
I pointed Chrome at http://192.168.200.2:32400/web, opened the devtools and grabbed the link from the console.
Then I put the host redirect into the pfSense DNS resolver config UI like this:
Host 192-168-200-2
Parent domain of host xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.plex.direct
IP to return for host 192.168.200.2
Seems to be working quite well … but when will xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx change?
It’s best to set the LAN domain override this way:
(This is from pfSense – allow all the hosts on your lan to use plex.direct)
Thank you - I’d tried that to no avail and was becoming more and more frustrated with the results.
This is my first rodeo with Plex, and I didn’t have much to lose, so I re-rolled from scratch just to make sure that I hadn’t done anything strange with the settings. I also removed the DNS entry from my OP, and cleaned up some other things.
Same problem. I made the suggested entry in the unbound custom options. No joy.
On a whim I plugged the URL into a browser, and this time I saw …
Imgur
Hah. Yes, I use OpenDNS, and yes, they were the ones causing the problem.
I did this and the problem went away …
Imgur
I’m still secure because ubound is protecting against rebinding attacks.
And to be certain, if I remove the private-domain: “plex.direct” setting from ubound custom options, it stops working again.
So friends, watch out for rebinding prevention at Open DNS - it will mess with your Plex.
