OpenELEC presentation for PLEX?
How about adding PMS to the image so I can also play files from my USB drive or streaming via DLNA (my PMS server is down due to a crashed hard drive).
That might not be possible, as I don't have access to the src of PMS and it would likely require a different build for each version. But if someone wants to test it out, the binaries from the Ubuntu/Fedora/debian packages are all the same. Based on a 10.04 LTS Ubuntu, so if binary compatible with OE it should work.
I'm focussing on the client for this project. For addon's feel free to pitch in. There is ssh axx to the OE builds.
- Mark
Okay, I'm officially moving my OE work to a central public section of the forums.
I've opened a thread explaining stuff you know but also how to report bugs, so we can track the better: https://forums.plexa...one-pht-distro/
I will add information to the project as I get wiser etc.
- Mark
I am trying to convert from my openelec 2.0 xbmc to the openelec 3.2 Plex edition.
I can boot the usb drive and everything works except sound.
This was the same problem that I had with xbmc.
The solution was:
http://wiki.openelec.tv/index.php/Config_sound_zotac_ion-a
I did the same on the plex edition but the sound menu is limited on the plex edition.
Xbmc edition:
http://1drv.ms/1ghMNIY
Plex edition:
http://1drv.ms/1ghMPRa
Also the reboot works fine but the shutdown closes plex and reopens it. It never shutdown.
Everything is tested on the live edition!
For audio have you tried following the Plex Home Theater audio guide: https://plexapp.zendesk.com/hc/en-us/articles/201214687
  • Mark
That was the first thing I've tried but I doesn't help :(
Hi Mark,
Im sure this will have been asked before so appologies if it has but do you know if your openelec build will work on the CuBox http://www.solid-run.com/cubox It would be great to have a full blown PHT running on this.
Shaun
Hi Mark,
Shaun
+1 Yeah, the Cubox is a great little piece of hardware.  I'm currently running OpenElec on it and just settling for PlexBMC.  It'd be nice to have a native PHT, PlexBMC is clunky.
Since OE is already running, shouldn't be that hard.  I'll take a look and see if I can't figure it out.
-Phil
-Phil
You will have better luck looking at Rasplex for cubox as it's arm based. I'm only focussing my efforts on Intel based platform. But it's a cute little box the cubox-i.
- Mark
re-up this topic...
I'm still always interested :-)
re-up this topic...
Why re-up? OE with Plex Home Theater exists: https://forums.plex.tv/topic/87943-openelec-plex-home-theater-the-all-in-one-pht-distro/#entry509680 just not for random arm platforms, for that there is RasPlex.
- Mark
Hi Mark,
I use both XBMC and Plex.
Earlier this year when I updated my NUC from OE (with XBMC) 3.2 up to 4.0 it really smoothed things along, since then I tried your Plex on OpenElec. While I love having a slim OS build with Plex HT. I have a few problems.
1,When changing screens the entire screen flickers
2,it appears like the colour space isn't correct for the hardware (fixed in OE 4 xbmc)
Anyhow, thanks for all the hard work
Best regards
Ali
Hi Mark,
Best regards
Ali
Yeah hope to get the benefits of OE 4.0 and the Gotham stuff.
Flickering stuff, have you tried setting vsync settings to only during playback?
- Mark
Did the deed at the weekend. Now all Plex and no XBMC!
Works perfect on oE with my 2820 NUC!
But.
The context button doesn’t work! Using either a standard MCE remote or a Harmony. It works with a keyboard pressing the C key.
Is there a guide to edit an XML file?
Other than that it’s spot on!!
I've been running the 1.1.3.121 ION build for a few months now and love it, however I notice the update functionality seems to do nothing, I presume because this hasn't actually been built.
Is there an easy way to update the Plex binary or do we need to do a fresh installation every time we want to update? If the latter, is there any advice to streamline the process? (maintaining system preferences etc)
Many thanks!
Dan
Many thanks!
Dan
The normal update procedure for OE is (if auto update works) is to pull the SYSTEM and KERNEL file down to the /storage drive. This folder is also shared over the network. And then reboot OE.,similar method can be done manually as shown here: http://wiki.openelec.tv/index.php/Updating_OpenELEC
Auto updating is planned. And half implemented.
- Mark
- Mark
Perfect, thanks a lot Mark, exactly what I was looking for!
Hi All,
   Sorry to distrub you guy's.Am biginner for PHT>I have installed new version of Plex Home Theater.1.2.2 on ubuntu14.04 LTS.When i enter into this path(opt/plexhometheater/share/XBMC/addons/skin.plex/media) i haven't seen any png files.there is only one file that is texcture.xbt.
I have been playing with PHT on VM with Ubuntu.  I have a Rasplex up and running but want to move up to a more powerful system.  I see that OE and PHT are running great on NUCs but I am considering less expensive hardware from Gigabyte.  Has anyone here tried OE + PHT on the following hardware?
Gigabyte Intel Celeron N2807 Mini PC Barebones GB-BXBT-2807
2 GB of RAM
16 GB SATA III SSD
OE
PHT
FLIRC USB Dongle
Any help, guidance, comments would be appreciated.  I'm trying to build as many as 5 of these boxes so I really want to keep the cost down and I find the NUCs a bit pricey.
Thanks in advance,
Keith
Great work Mark. Is there also a script for Linux? I mean to have it like under windows, that the script makes a boot stick. I do use Linux myself but I cant programm. Thats why I am asking. I do have also a Windows PC so I dont mind if you say no. I just think there are also people using Linux, which dont have a Windows PC. Just a thought.
Hi everyone,
I have this running great on my Chromebox.  I only have one problem...my blacks are all washed out.  They are more like dark greys.  Is there any way to dig deeper into the video settings than what there seems to be?  Is this a common issue or am I an oddball?
Thanks!
EDIT: I figured it out. I had to perform some SSH wizardry.  I still have no idea why I needed to use SSH to do this and why it's not in the settings  but hey, it works.
