Using a windows server version 1.23.5.4841. If you have a lower converted version of a 4k film e.g 720 (low quality) and then set to convert to an optimised version 1080 (medium quality). 1080 is not converted it registeres as complete in optimed versions but no 1080 optimised version is created. Workaround is you have to delete 720 version first, then it will create a 1080 version.
Further conversion issues found. The optimised version does not include access to the original files vobsub subtitle stream, and if you convert a film that last had subtitles selected as on in a client it burns them into the optimed version?
It was also be good to have an option for higher 1080 quality conversions of a 4K film e.g 30mbps
