Option to assign whole star ratings
I’m in the process of assigning star ratings to my whole library, a daunting task! But I’m very happy with the star rating system, with the small exception of the input of the rating itself. I personally only want to assign whole stars to my songs, but the “buttons” for assigning those stars in the interface are so small that usually when I hit something like the third star, it assigns a value of 2.5 stars. Then it takes several taps before I hit the sweet spot and finally get it to three stars.
It would be awesome if there were an option that allowed both behaviors, by allowing me to say I only want whole stars and make the star buttons bigger for easier rating selection.
I sincerely appreciate your excellent work on this app. It is very nice and I don’t mean to sound whiny.
If you are on a PC or Mac, you could define a few global hotkey combinations.
This’d have the added benefit that you can rate your songs while Plexamp is playing in the background while you are working with a different app in the foreground.
Thank you for the suggestion! Unfortunately, I am specifically using the mobile version of the app.
