My workflow is the age old one. Scan the channels you expect something good on, then the less likely, then the dross.
Can you just add a sort by channel, preferably using some constant like the Freeview number.
It’s currently just a pain in the ■■■■. I do Plexy things with the rest of my media, but this is not something I need to adopt a new workflow for.
Ta
