Server Version#: 1.18.8.2527
Player Version#: 4.28.3
I’m having an issue with matching Movies, where the Originally Available field is set to 1900-01-01 for some reason. Even after removing or manually changing the field and matching the movie, it will revert back and the movie will not actually be matched (usually the synopsis is there, but no poster). All of my movies are organized by /Movies/MovieName (release year)/MovieName (release year).ext
That’s good - leave it there and also under ALL tabs in Movies and Shows.
(Plex Movie/Movie Database/TVDB/ALL Tabs)
Dump the agent caches:
Eventually we’ll either find it, or find a reason to start looking at log files.
(and do disable Verbose Logging while enabling Debug Logging)
(Server/Settings/General)
