Server Version#: 1.24.5.5173
Player Version#: 4.68.0 (Plex Web) [& latest version on LG TV]
Installed latest updates (both to QNAP and Plex) a week or two ago, all been working fine since. Went to watch a recorded item this evening on my TV and found it couldn’t connect to the server. Went to PC and same issue via Plex Web - only showing cloud content with exclamation marks for all the local libraries.
I stopped and started the service on QNAP and all working again however the recording never took place - reported as channel not available.
I’ve had a look at the logs and before the restart logs the last entry was in the early hours of the morning -
Nov 02, 2021 03:39:43.733 [0x7f60a85c7b38] DEBUG - [JobRunner] Job running: '/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/CrashUploader' '--directory=/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Crash Reports/1.24.5.5173-8dcc73a59' '--version=1.24.5.5173-8dcc73a59' '--platform=Linux' '--platformVersion=QTS 5.0.0.1828' '--serverUuid=[REDACTED]' '--userId=[REDACTED]' '--sentryUrl=https://sentry.io/api/1233455/minidump' '--sentryKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx' '--vendor=QNAP' '--model=x86_64' '--device=TS-451+' '--allowRetries=0'
Nov 02, 2021 03:39:43.748 [0x7f60a85c7b38] DEBUG - [JobRunner] Jobs: Starting child process with pid 19823
Any suggestions? Happy to send full logs to a mod if helpful.
Also is there a way to watch for this sort of crash and issue a service restart command?
