Own trailers for TV Series?
Hi everyone!
So, I’m currently replacing all my film trailers with trailers I have retrieved. I have found that although paying for a Plex Pass, some trailers either aren’t trailers and are a film reviews, like an extra, or are in such bad quality even my grandma would turn her nose against and skip even though the actual film is in HD.
DON’T WORRY PLEX, I will continue to support, its just an area you need to improve on. Just like having trailers for TV series…
I have had a snoop around the forum and I can only see that if you are lucky, there’s a handful of TV series with trailers, although non of mine do.
Is there a specific naming sequence, for example ‘See S01-trailer’ I can add? Is there anything planned for the future to add our own if not available for Plex Pass?
Thanks Plex people :smiley:
I can’t make any promises about TV trailers. There is no current support for TV extras. The only thing you could do right now is add it with a fake episode number in specials or the regular season
if you want it to show up before season 1 episode 1 then name it See S01E00 . I did something similar for the Battlestar Galactica 2004 miniseries so it shows before episode 1. You will need to manually add the title if it is not embedded in the files metadata
13%20PM
29%20PM
Ahh, thank you very much. This is what I had found in a previous forum post I hoped had been resolved 2 years later.
Thank you and keep up the good work.
